det62
MD
What size are you looking for?
1994 Georgie Boy Pursuit 32 foot Class A
Debbie (owner, pilot and navigator)
Steve (campfire starter)
Matthew - age 17 Got Fish ??
Rebecca - age 16 Got Wi-fi ??
Bob Vaughn
Seffner, Fl.
I replaced all my cam locks with slam latches that I got from Tweeties in Tx and they work great......
RollingRockTX
Keller, Texas
det62 wrote: What size are you looking for?
Sorry had Jury Duty today, had to do my part...was picked for a civil trial
Here is a picture of the current cam.
I need this to be about 1/4 inch longer to catch the lip on the inside of the door.
2006 Ford F250 King Ranch PSD
ARP Headstuds
ERG Delete
Diesel Site Coolant Filter System
Gearhead Performance Tuned, via XCALII, Edge Insight CTS
MBRP 4" Turbo Back, cat delete
MagHytech Rear Dif Cover
2011 Ford Expedition, HD Tow
2011 Cruiser CF33LF, KC5PFG
Locky
West Michigan
If you have the old cam locks that came off of it then there's a chance you can take those cams off and put them on the new ones. If the old cams did not secure with a screw but looks like they have been pressed on then if you have a grinder just grind down where they have been pressed down at and there's a good chance it has the same square knockout. Or head to your local lock shop and they should be able to sell you some longer cams.
snowshe
alberta
I have the same problem with the basement door. Over time it looks like the camlock moves up in the oval hole in the door. I just loosened the lock and re-positioned it lower down so the it latched in the frame. It would be better to have 1/4" longer latch and when I find one I'll change over (or replace the whole lock assemble). I have had to so this 2x.
Bob and Marlene
2008 COLORADO 28RK 5er
2006 GMC 2500HD Crew 4X4 SRW Duramax / Alison 6spd
Reese round tube slider with 15000lb 4way tilt
Podigy brake control
Don't Buy New -- Reuse and Recycle DRIVE a HOT ROD
1946 Chev Fleetline Resto mod
jyh818
Chino, CA
Check Home Depot or Lowe's. They have cam locks, too.
2002 Ford Excursion XLT 6.8L V-10 2WD, 4.30 Limited Slip
Rear Hellwig Sway Bar
2009 Skyline Nomad 260
Prodigy Brake Controller
EAZ-Lift WD Hitch
KA4EBU
memphis,tn,usa
There are a lot of mfg and importers of cam locks..They use different size squares on the back of the cylinder to attach the cams..Common cams lengths of up to 2 1/2" are usually readily available..
I am not familiar with this vendor, but a search brought up his page..
This item is what is needed on panels that are not solid, will hold the camlock in place..
http://www.mrlock.com/24041.html
Don and Pauletta
2003 Phaeton 40RH
2008 Jeep Liberty Limited 4x4
2005 FLHTUCI
Misty - a spoiled Maltese
