RV.Net Open Roads Forum: Tow Vehicles: LMM wont start PLEASE HELP!
Search only in Tow Vehicles
 > LMM wont start PLEASE HELP!
chaunceyL
ORANGECOUNTY
Posted: 02/27/12 11:09pm Link  |  Print  |  Notify Moderator
Hello guys as some of you know I just got my first diesel 08 duramax ....so today I was going down the road the hauling about 3500lbs of dirt the truck just went into limp mode and just died and still wont start and the little picture of a motor light is on .... on top of that AAA didnt have a truck heavy duty enough to tow it!!!they put the arms under the rear end and tried to lift it and no go so we gotta get another truck , but if any of you have a clue please help.
chaunceyL
ORANGECOUNTY
Posted: 02/27/12 11:12pm Link  |  Print  |  Notify Moderator
Truck is complety stock with 231k on it .....turns over but wont crank
kaydeejay
SE Michigan, USA
Posted: 02/28/12 01:50am Link  |  Print  |  Notify Moderator
Do you have less than 100K on the motor? If so you are under warranty - call a dealer.
But to me it sounds like a fuel issue - have you tried priming the system or even changing out the fuel filter?
Edit: - Ah, missed the 231K bit in the second post. SOL on warranty!
Code reader sounds like a good idea.
Let's hope it's not the fuel pump!
* This post was edited 02/28/12 05:47am by kaydeejay *
Keith J.
1999 Sunnybrook 27RKFS Fiver.
2005 GMC Sierra 2500HD CC/SB/DA 2WD, LBZ air cleaner, 52 gal Titan tank, Bilsteins, Line-X, Westin steps, Prodigy, Retrax cover, 16K Superglide, 5th-Airborne pin-box, Multi-vex mirrors, TST TPMS.
yankeeflyer
Summer:Prince Edward Island,Winter:On the road
Posted: 02/28/12 04:20am Link  |  Print  |  Notify Moderator
It's either the fuel filter or fuel injector harness in my experiance.
2005 Chevy Silverado 3500 Diesel Dually.2007 Mobile Suites 38RL3 Fifth WheelRetired July 06 Follow our Rainbow Family and Travel
Mote
Westport, indiana
Posted: 02/28/12 04:28am Link  |  Print  |  Notify Moderator
Sorry I can't help but this website should be able to. www.dieselplace.com
1996 Dodge Ram 2500 extended cab 2wd, Indy 500 edition Cummins diesel
2002 Jayco 325 BHS
NewsW
US
Posted: 02/28/12 04:56am Link  |  Print  |  Notify Moderator
Get a code reader and read the codes.
LIKE2BUILD
Mt. Zion, IL
Posted: 02/28/12 08:10am Link  |  Print  |  Notify Moderator
True. To many possibilities to make guesses. Once you post the codes it's a lot easier to suggest options.
As for the wrecker. Can they not take the driveshaft loose and tow you from the front? That's a pretty common method when towing heavy trucks.
KJ
'02 Jayco Qwest 324G
'04 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1 | Eaton Posi-Trac
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
2000 Crownline 205BR
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (12, 6, & 4)
1 forgiving wife!!!
mapguy
Puget Sound
Posted: 02/28/12 09:24am Link  |  Print  |  Notify Moderator
Confused by this statement.
My first read thought you said "cranks over but won't start" but on reread I am not so sure.
A plugged fuel filter can easily cause a limp then a crank but not start condition.
Code Reader is a good start -it points you towards the problem that the ECM didn't like that caused the limp.
chaunceyL
ORANGECOUNTY
Posted: 02/28/12 10:17am Link  |  Print  |  Notify Moderator
Thanks guys I said something about said method of towing it from the front and let's just say we I passed on it after both tow drivers looked at me like a deer in the head lights .... So I guess I'll have to get the codes pulled .... What about disconnecting the batt??
chaunceyL
ORANGECOUNTY
Posted: 02/28/12 10:44am Link  |  Print  |  Notify Moderator
Ohh yeah and is there some way of priming something from under the hood or somthing along those lines while some one inside the truck tries to start it ?
Thanks again guys !
