simbatoner
Portsmouth, RI
Going to be buying a TPMS. Looking at both TST and TireTraker.
Which one is better? Have been reading all the treads but not many mention TireTraker. I like the 3 year warranty.
Opinions please!
2012 Thor ACE 29.2
SOLD-2006 Jayco Greyhawk 27DS
Towing 2006 Honda Odyssey Touring Edition
on a MasterTow 80HDS
Gale Hawkins
Murray, KY
Only having two sets of TST TPMS systems I was biased after the first set.
bluwtr49
Green Valley, AZ
You might also look at Tire Safeguard.
Dick
2000 40" DP Beaver Patriot Thunder Cat C-12 425 HP, 1550 Tq
1997 Jeep GC Limited ---toad
2008 Toyota Tundra Crew Max Limited TRD (Retired)
2009 Cougar 268 RLS ~8700 lbs road wt (Retrired)
2006 Jeep Liberty Turbo Diesel.....TV in Training
stripit
Casa Grande, AZ
TST has a great track record for almost 5 years they have been around. I would go with a proven unit with a strong customer base if I was looking for a pressure monitoring system.
Stacey Frank
'04 Mobile Suites 36 TK3 #1341
'99 Int'l 4700 Lo Pro MDT
'08 Lexus 400H
More To See
San Diego Area
I tend to stick with what I know to be a good product until I have some really solid evidence otherwise. TST for me. Works really well and they have excellent customer support.
95 Winnebago Vectra 34 (P30/454)
chastho
arkansas
I have TireTracker system. it has it's problems but It is the only one I have had so I can't compare it to the other, just like the others can't compare TST to Tire Tracver. The biggest problems I have is it not giving you the tire pressures until you have driven for a short distance, I want to know the PSI before I leave home where my compressor is. I also get a lot of false signals. BUT like someone else said, it is better than nothing and the price is right. Before I leave home I check all tires with a gauge and depend on the system after that.
pkunk
Questa, NM
When I first got my TST system several years ago, I had a faulty sensor. It was replaced immediately and then I sent the bad one back. I needed new O-rings Mon., sent them a message and they arrived here today N/C. This is service on a par with Fantastic vent.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
BrokenElbow
Valencia, CA
With the TST, you will see the tire pressure before you leave. That's what I like so I can top off the tires before I leave if it's needed. Also they have great service. I can't comment on the others, the TST is the 1st system I have used.
2011 Montana 3455, MorRyde pin box, TrailerSaver BD3 air hitch, G614 tires, 2x6volt batts, 2 x Honda 2000i, Rotochoks, 6 pnt Levelup, TST TPMS, Arvika bike rack, Voyager Semi Wireless Rear Cam, Flojet Mascerator, 2008 F350 Lariat 6.4L diesel 4x4 SB CC SRW
fourmat
NJ
BrokenElbow wrote: With the TST, you will see the tire pressure before you leave. That's what I like so I can top off the tires before I leave if it's needed. Also they have great service. I can't comment on the others, the TST is the 1st system I have used. +1 they are very easy to deal with I had a sensor go bad mailed it to them and they mailed me a new one that simple
2009 Challenger
homerbw
San Antonio
I purchased tire tracker in December. One 400 mile road trip convinced me it was a winner. The tires might not show you the pressure you have before beginning a road trip but that does not mean they are not being monitored. If the tire pressure drops, moving or not, you will know about it. The only thing which bothers me is the occasional signal loss which does not last long.
2000 Pace Arrow Vision 36B, F53, 275hp Triton V10
