RV.Net Open Roads Forum: Tow Vehicles: Recommendations on a good Lt tire?
Search only in Tow Vehicles
 > Recommendations on a good Lt tire?
Kevin O.
Connecticut
Posted: 02/28/12 05:06pm Link  |  Print  |  Notify Moderator
I would like to replace my stock tires with a more durable Lt tire. They have to fit my 20" rims. Any recommendations??
KEVIN
DW-Debbie
DS-Tyler 7yrs old
DD-Makayla 4yrs old
MERIDEN,CT
2011 FORD F150 SUPERCREW FX4 Ecoboost w/Max Tow Pkg and 157" wheelbase
2006 SHAMROCK 21ss(Sold)
2012 Keystone Outback 292BH(New)
Golden_HVAC
Fulltime, CA, USA
Posted: 02/28/12 05:48pm Link  |  Print  |  Notify Moderator
HI,
I use a all steel Michelin RIB tire, that has much stiffer steel sidewalls, not the softer polyester sidewall tires. It really helps in preventing the trailer from "Pushing" the back of the vehicle around and into corners when going down hills on a 2 lane road.
Fred.
abc40kids
Dale City,Virginia
Posted: 02/28/12 05:59pm Link  |  Print  |  Notify Moderator
Look at www.nittotire.com
Jeff,Julie,Amber,Brandon,and Casey,Dexter(Golden),Bruno(Pug)
Forest River Cardinal 362bhs 2006
2005 Chevy duramax dually 4x4 crew cab,Ultra Goliath wheels with Nitto Dura Grapplers and Banks exhaust.
NewsW
US
Go to the website tirerack.com see what fits and then read the reviews.
Dick_B
Palos Heights, IL USA
Posted: 02/28/12 08:17pm Link  |  Print  |  Notify Moderator
Michelin
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
MM49
Brighton, MI, USA
Posted: 02/28/12 08:19pm Link  |  Print  |  Notify Moderator
Try Nexen tire, LT truck tires. They look pretty darn good. I have a 2012 with Michelin and am not happy with the results so far. My last 2010 truck with Michelins' made it only 60k and had 3 leakers. Today's Michelin is not yesterday's Michelin.
MM49
www.nexentireusa.com/
garryk6
Kodiak, AK
Posted: 02/28/12 08:55pm Link  |  Print  |  Notify Moderator
I have had several sets of the BFG AT's and they come in about every size imaginable including 20's. That said, I have also had Toyo Open Country AT's. For mild off road, snow etc I have had very good luck with both,and they are fairly quiet too. But the BFG AT seem to wear a bit better and longer. Just make sure and spring for the Load Range E vice D. You may not NEED Load Range E, but they will wear so much better!
Good Luck!
Garry in Kodiak, AK
Garry K
Wife + 4 kids
Retired Military Family.... Alway's on the move....
2002 F350 CCSB 5.4 6spd 4x4 in AK
1966 Avion C-10 Truck Camper
Lad79der
Bucks County, PA
Posted: 02/28/12 08:58pm Link  |  Print  |  Notify Moderator
I am running Yokohama Geolander ATS on my Cummins 2500... good tires. Load Range E!
2007 Ram 2500 5.9HO Cummins 4x4 Quad Cab 6spd Manual
2007 Cherokee Lite 28A+ TT
steelpony5555
Copperas Cove Texas
Posted: 02/28/12 09:03pm Link  |  Print  |  Notify Moderator
BF Goodrich now on both the truck and trailer, on my last truck I had Michelins and the sidewalls were all cracked up long before the tread wore out, and were only 3 years old. I agree you pay alot for the name and now they are not the same tire they used to be.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
BenK
SF BayArea
Posted: 02/28/12 09:57pm Link  |  Print  |  Notify Moderator
A good tire shop will check whether your wheels are capable of handling the higher
pressures of the next higher class tire than what comes with most half ton trucks
If not, best to check the wheels yourself, as it mandated to have the PSI rating
somewhere on the wheel, along with the rest of the wheel spec's
-Ben Picture of my rig
