David0725
Has anyone used the Gen-turi Generator Exhaust System? if so can you tell me does it get hot to the touch. so my Generator Exhaust come's out infront of my front driver side tire how would I install one there?
thank's David
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
SPRING STREET
LOUISVILLE KY.
They are made out of pvc and don't get hot, maybe warm by the base. My exhaust also is like yous, so i get a couple of those suction cups with hooks and rig small bungees in a couple of spots.. works for me.. Rarely use mine unless we are at the races where the spots are small, although I never leave home without it ,just in case..
2005 MOUNTAIN AIRE 4304, FMCA F334596, Good Sams and KOA member..TOAD 2012 Ford Edge with the Eco Boost Engine, License plate "TOWED" > RoadMaster All-Terrain Tow Bar and Base Plates.
David0725
I appreciate the quick reply I think I will get one. I know it wont get used much but I am thinking going to some concert's this year with no hook ups.I do see people 10ft away useing theres without the pipe.
Jim@HiTek
Gresham, OR, USA
Remember to watch out for yourself, if you're next to someone using a genset without one, be prepared to talk to them...you don't want to go to sleep in your rig with your neighbor running theirs.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
steveownby
Cosby, TN
They do get hot to the touch but not dangerously so. It will work find with your configuration.
Steve Ownby
2003 Monaco Signature
Full-time since 2007
Jim@HiTek
Gresham, OR, USA
I made my own out a 90° metal pipe (1 & 1/2") connected to the exhaust pipe of the genset. Then I fashioned a metal coupler to three metal straps to a 4" PVC coupler. There is a 2" gap between the metal 90° portion and the start of the PVC. The metal straps connect to a PVC coupler. The next section of PVC pipe (4') is fitted into the coupler, then another coupler to 2" pipe and so on. The pipe gets warm, but not hot. Also use suction cups and bungees as mentioned. Rests next to the RVs side and exhausts above the roof.
Gen-turi, or something similar, is recommended, especially if you boondock a lot. The are required at some venues as some deaths have resulted from close packed RVers running their gensets. Neighbors have died. I remember 3 deaths last year at a big rally.
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
I use mine primarily at NASCAR races and it works really well. As others have stated, it does not get hot.
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
Doug and Cassi Glass
Clifton Forge, VA
Use one all winter in Key West. The metal part gets hot, the plastic gets warm.
They should be a requirement in every campground where generators are used, especially diesels where the gen exhaust goes right in the neighbor's door.
Ivylog
Blairsville, Ga. USA
I've made several for less than $17.
04 Monaco Dynasty 42' quad slide
Where am I?
How I tow.
M GO BLUE
Southgate, MI
Would not leave home without ours...it goes on every time we stop if we are staying more than a couple of hours...
We attach ours to the side of your fifth wheel using 3" suction cups (available at Walmart) and bungee cords...
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
