RV.Net Open Roads Forum: Travel Trailers: Jeep Grand Cherokee Towing Weight Limit
 > Jeep Grand Cherokee Towing Weight Limit
Ullr
Park City, UT
Posted: 02/28/12 09:38pm Link  |  Print  |  Notify Moderator
I have a 2004 Jeep Grand Cherokee with the 4.7L V8. I have read on TrailerLife.com the vehicle has a towing weight limit of 6500 lbs. But that it should have a "Towing Package". No explanation of what this package would be. No information on Jeep.com what it would be as well. The local Jeep dealer is just steering me to the Jeep.com website. (Which is of little help.) Can I safely tow a trailer with a weight of approximately 6,000 lbs Fully Loaded? I need to know the answer to this ASAP! (Gross travel trailer weight is approx. 5300 lbs.)
Chuck&Gail
In the Colorado Mountains
Posted: 02/28/12 09:58pm Link  |  Print  |  Notify Moderator
Doubtful. Bet your tongue weight spec is 650#. Using minimum of 13% your max TT weight is 5000#.
Usually tow package is trans cooler, hitch, and 7 pin wiring, but can't say on your Jeep, sorry.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
hmknightnc
Wilmington, NC
Posted: 02/28/12 09:59pm Link  |  Print  |  Notify Moderator
Hi and welcome to the forum. Unfortunitely the answer to your question is not as easy you think. If you are unsure if your vehicle is equiped with the towing package generally the easiest way is to take the vehicle VIN number to the dealer. They should be able to run the VIN number and tell you whether it is already equiped with the package or not.
Another way that might help you determine if the vehicle as built is capable of the load according to manufacturers ratings is to look at the GVWR and GCWR on the drivers door sticker. The difference between these two numbers is the towing capability in theory.
Towing packages vary by manufacture but generally they include the following equipment if not already part of the standard offering. Engine oil cooler, Auxiliary Transmission Oil Cooler, Hitch, Trailer plug wiring (7 wire), heavier sprngs and bigger brakes
Hope this helps
APT
SE Michigan
Posted: 02/29/12 05:41am Link  |  Print  |  Notify Moderator
Stick to under 4000 pounds dry with under 400 pounds dry tongue weight.
2012 VW Passat TDI
2017 Subaru Outback 3.6R
skipnchar
Topeka or somewhere else
Posted: 02/29/12 06:57am Link  |  Print  |  Notify Moderator
Here's the link to the Jeep WEbsite and their trailer towing specifications for the GC model. http://www.jeep.com/en/2012/grand_cherokee/capability/towing/
Just be sure you read the ENTIRE thing, not just the headlines [emoticon]
Good luck / Skip
Group IV Trailer towing package
Includes: Rear Load Leveling Suspension, 220-amp Alternator, Heavy-Duty Engine Cooling, 7- and 4-pin Wiring Harness, Class IV Receiver Hitch, Full-Size Spare Tire, Steel Spare Wheel, and Delete Rear Tow Hook. Available on:
Ron Gratz
full time RVer
Posted: 02/29/12 09:41am Link  |  Print  |  Notify Moderator
Ullr wrote:
I have a 2004 Jeep Grand Cherokee with the 4.7L V8. I have read on TrailerLife.com the vehicle has a towing weight limit of 6500 lbs. But that it should have a "Towing Package". No explanation of what this package would be.---
The following is from
2004 Jeep Grand Cherokee Options
Trailer Tow Group Iv -Inc: 7 To 4 Pin Wiring Connector, Pwr Steering Cooler, Class Iv Hitch Receiver, 7 Pin Wiring Harness, 6500# Max Loaded Trailer Weight, 750# Max Tongue Weight, 64 Sq Ft Max Trailer Frontal Area, 30Ft Max Trailer Length, Plastic Receiver Cover, Under-Dash Provision For After Market Trailer Brake Connector (Req: 2_Y Columbia Edition Quick-Order Pkg Or 2_H Freedom Quick-Order Pkg) (Req: Eva 4.7L V8 Engine)
Does your GC have a factory-installed hitch receiver? If so, what are the ratings printed on the receiver?
Ron
John & Angela
World Travelers.
Posted: 02/29/12 09:57am Link  |  Print  |  Notify Moderator
Well, right out of the box there is a problem with the trailer. You stated 5300 pound GVW and 6000 loaded. That is a recipe for bad things happening.
Rule of thumb when looking for a trailer, look for high GVW's and low dry vehicle weights. That way your axles, tires AND BRAKES have a chance.
Don't worry about what the GVW of a trailer is when buying it other than making it as high as possible. Worry about loaded vehicle weights and tounge weights.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
youth4him
Belgrade, MT
Posted: 02/29/12 05:51pm Link  |  Print  |  Notify Moderator
We towed with a GC at one time, and it was a bit underpowered, but the real issue was the length and the 4x4 rear end. Those trucks are by design, set up for off road, which gives them a bit of drag-ass when you put a trailer on it. I actually had to put airbags in to compensate.
Agreed with what other say here, stick with a lighter trailer than you think you'd need and you'll be happier, push it, and you'll likely find yourself miserable when towing.
KD
Trip of a Lifetime Blog - 12000 Miles, 100 Days, 34 States, 4 Humans, 1 Mini Daschund...FUN!
2007 GMC Yukon XL Denali - 6.2L, 6-speed
Gene&Ginny
North Kingstown, RI
Posted: 02/29/12 06:14pm Link  |  Print  |  Notify Moderator
I used to have a 2000 Jeep GC w/4.7L V8 and the factory towing option. It was rated to tow 6,000#. My TT Gross rating is 5500# and weighs 5000# on the scale, loaded. (4300# dry for those that have to use that unusable number) The "factory" options included the tranny oil cooler and extra capacity on the rear springs. The tongue weight rating was higher than 650 WITH a WD hitch but I can't recall the exact number.
I recall looking at the numbers available at the time and the factory towing option DID make a difference.
Gene and DW Ginny
2008 Toyota 4Runner 4.7L V8 w/factory towing option
2002 Sunline Solaris Lite T2363
Reese Dual Cam Straight Line HP Sway Control
Proud member of the Sunline Club
Ron Gratz
full time RVer
Posted: 02/29/12 06:40pm Link  |  Print  |  Notify Moderator
Gene&Ginny wrote:
I used to have a 2000 Jeep GC w/4.7L V8 and the factory towing option. It was rated to tow 6,000#. My TT Gross rating is 5500# and weighs 5000# on the scale, loaded. (4300# dry for those that have to use that unusable number)---
Thanks for providing what you consider to be an "unusable number".
Some of our members recommend that, if you tend to load "light", you can plan to add 500-1000# to a trailer's "dry weight". If you take the middle of that range (750#) and add it to your "dry weight", you arrive at an estimated GVW of 5050# versus your scaled weight of 5000#.
Looks to me as though the "dry weight" could be a usable number after all.
It's also good to see you didn't load to 100% of your trailer's GVWR.
Ron
© 2017 CWI, Inc. © 2017 Good Sam Enterprises, LLC. All Rights Reserved. | Terms of Use | PRIVACY POLICY | YOUR PRIVACY RIGHTS
