RV.Net Open Roads Forum: Another case of dreaded 2011 Ford 6.7L HPFP failure?
Search only in Tow Vehicles
 > Another case of dreaded 2011 Ford 6.7L HPFP failure?
Page of 10
hoopers
Loveland, CO
Posted: 02/29/12 07:03am Link  |  Print  |  Notify Moderator
NewsW wrote:
hoopers wrote:
NewsW wrote:
In general, if you do not have a specific power/torque need you should not buy a diesel.
There is no cost advantage with diesel fuel priced higher, and maintenance in the medium duty truck range.
The diesel cost disadvantage is changing. Down to around 5-10% now. It was at 20%.
I did the math and got this...
Routine diesel oil and filter change $150 to $200
Routine gas V 10 service: $60
Difference in capital cost $10,000 (or more)
If you got 20% better gas mileage in the diesel --- how many miles to make up for the difference @
Diesel (your local price) vs. Gas
There was a time when diesel was much cheaper than gasoline. The reverse situation has only been true for the last 5 years or so? But we digress from the OP's original topic. IMO, diesel is more a case of the right tool for the job. I bought a brand new 96 Ford Diesel and drove it for 14 years with basically no issues.
I do pay close attention to HPFP failures, since I have a 2011 duramax...though I would add the conclusion is FAR from certain. What is true (IMHO) is there are HPFP failures on Ford with Ford denying warranty claims.
It took several years to figure out the 6.0...for example, just recently, there is a lot of blame on the radiator cap for some of the 6.0 issues. Years from now, will we find out many of the HPFP failures were due to something really simple and cheap to fix (i.e, like a radiator cap)???
Today, the fix is a 12000-18000 dollar complete fuel replacement job...I would think there is a muuuch cheaper solution, once the real problem is figured out.
2011 Silverado CC DRW 4x4
2013 Bighorn 3670RL
Texas gulf coast, Colorado, or on the road camping somewhere
Ranger Smith
Wherever the rig is parked
Posted: 02/29/12 07:07am Link  |  Print  |  Notify Moderator
Interest rate
Opportunity cost
I just had an oil change done at dealer and it was 79 bucks for my diesel.
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
Ranger Smith
Posted: 02/29/12 07:24am Link  |  Print  |  Notify Moderator
NewsW wrote:
If you can get 5 gallons (or thereabouts) of Diesel grade oil and filter and lube etc done for that... all the more power to you.
Normal price is way higher.
Do the math, what does it cost for 5 gallons of oil and filter, before they charged you for shop time?
I am not counting loss leader oil changes like $19.95 advertised prices either!
Well for starters my truck does not take 5 gallons of oil. I'm telling you that is what I normally pay. My Ford 6.0 was 99 bucks at the dealer.
NewsW
US
Posted: 02/29/12 07:09am Link  |  Print  |  Notify Moderator
Ford put out a manual for contaminated fuel warranty denials and then updated the software to log water in fuel sensor lights.
The common causes are apparently... DEF put in fuel (the port is next to each other).. and a lot of water and WIF warning ignored.
The problem is, by tripping the flag at WIF warning --- when operators are suppose to have a decent interval from detection to mitigate the problem --- is patently unfair to even the consciousness owner.
If it is that sensitive, there should be a secondary WIF detection sensor just before the pump that shuts down the engine before water gets in.
Putting the DEF port next to the fuel fill is asking for trouble.
The point is, the bulletin exclude the possibility of a failure by the CP 4 pump.
Quite wrong.
Lantley
Ellicott City, Maryland
Posted: 02/29/12 07:18am Link  |  Print  |  Notify Moderator
NewsW wrote:
Lantley wrote:
Exactly bad fuel = $6000.00 repair on a brand new truck. If that is the case. Buying a Ford is to much of a risk for me!
10,000 to 12,000, me think.
A $10K repair bill on a brand new truck is absurb unless there was proven willful negligence on the owners part.
A poor design by Ford + a policy designed to avoid the huge warranty claims of the 6.0 = Buy a different brand with less risks involved.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
NewsW
US
Posted: 02/29/12 07:21am Link  |  Print  |  Notify Moderator
garysol
Avon Ohio
Posted: 02/29/12 07:25am Link  |  Print  |  Notify Moderator
Thats the normal price at my local Dodge/Ram dealer as well.......
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
Powerdude
Arizona
Posted: 02/29/12 07:36am Link  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
milsuperdoc wrote:
I was at a ford forum and there's another report of dreaded 2011 Ford 6.7L PSD HPFP failure. Once again, it sounds like Ford denied warranty claim. This concerns me greatly since I'm expecting a delivery of a new 2012 F-350 with PSD 6.7L in about two weeks. I'm seriously considering not taking delivery of my vehicle, and cancelling my order.
http://www.ford-trucks.com/forums/1142885-engine-failure-on-2011-ps-6-7-ltr.html
The guy admits he got a bad tank of fuel. So much in fact that he had to drain the filter several times. He kept on driving and hosed his fuel system and you want to cancel your order?
IMHO there are far more dropped valve problems in the 6.7 than hosed fuel systems but you say nothing about that?
Ford has had 10 years to design a decent diesel, and a decent fuel system.
Bad fuel existed before the 6.7 liter, however the fuel system for the new engine is far more sensitive to water in fuel than the previous 6.0, 6.4, and 7.3.
I would not drive a Ford 6.7 L diesel if you gave me one for free. Don't need any more headaches these days. $12,000 to fix a fuel system that was poorly designed in the first place? No thanks.
For that money, you can get a used 7.3 with 200k miles on it, and have years of trouble free service, after putting in maybe 3k to solve some age related issues.
NewsW
US
Posted: 02/29/12 07:41am Link  |  Print  |  Notify Moderator
Did a check of filter prices:
Ford 6.0 List $28
Ford 6.7 List $20
Duramax 6.6 List $25
Cummins 6.7 Not listed.
What is the cost of 5 gallons of Diesel Grade oil where you are?
My cost here is around $50 for a 5 gallon bucket (4.5 gallons used) for Shell Rotella T
Ranger Smith
Posted: 02/29/12 07:48am Link  |  Print  |  Notify Moderator
Ford 6.0 List $28
Ford 6.7 List $20
Who cares what your prices are. I told you what it normally costs me. If you want to pay $150 to $200 bucks for an oil change that is fine it is your money. Also as I said my truck dosen't take 5 gals of oil.
This thread has nothing to do with oil change prices anyways.
Page of 10
