I went to 4-stroke outboards because I didn't like the smell of my ring-a-dings. We never added 2-stroke oil to the fuel of the 2-stroke Jimmy's........
Run whatever makes you feel good.
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
Suck squeeze bang blow - slang for the four cycles used in internal combustion engines - A.K.A. intake, compression, power and exhaust.
I have never put 2 cycle oil in my diesel but Canadian diesel has a higher minimum lubricity rating. It was mentioned on a recent (closed) thread regarding Fords 6.7 pump issues.
Supreme Oppressor wrote: Suck squeeze bang blow - slang for the four cycles used in internal combustion engines - A.K.A. intake, compression, power and exhaust.
Mad Norskey...........The only problem is............there are way too MANY people walking around Happy.
2000 Ford SuperDuty F-350 Powerstroke,Dually..The Tow Monster
2000 Cardinal 27RK LX
Prodigy Brake Controller
Honda EU3000is Generator
Raytek IR temp,Garmin 1300 /GPS
Doran Pressure Pro
VU Qube Satelite Rally's attended so far-16 My Blog
Good Sam Member
bfast54 wrote: Mad Norskey...........The only problem is............there are way too MANY people walking around Happy.
Yes, I know. I really, really like my new truck. Fun to drive, responsive, all sorts of neat stuff inside. Problem is, I read forums like this for entertainment, and frankly, I'm NOT entertained by all this doom and gloom.
Sure hope mine is the oddball that nothing happens to.
As of Oct 1, 2010 all on/off road diesel sold in Canada was to be ULSD <15ppm Sulphur. ( June 1, 2006 on road diesel had to be ULSD <15ppm Sulphur sold in Canada)
Low luricicty diesel fuels (<15ppm Sulphur) are required to have lubricity additives added at the refinery in Canada (but not in the US).
Lab lubricity tests are poor (procedures) and may not show presence of additives.
Fuel viscosity effects nozzle spray patterns, filter restrictions and lubricity/wear.
Think about this... where there is bad fuel problems it not only effects one vehicle, it effects many vehicles. If only one vehicle is effected, then its due to dirt (poor maintenance, did I get dirt in the filter housing when changing the filter?) Did I routinely drain the fuel filter to check for water? Or poor quality filter(s).
Owning and operating a Diesel equipped vehicle requires alot more preventive maintenace then your run of the mill gasser. Some, if not all of the failures can be pinned on the owner/operator which one can blame on the manufacturers and sales hype, meaning did I really need a diesel powered truck? Or am I trying to keep up with Jones'?
I've seen way too many individuals jump in their diesel trucks, that have no idea when or how to change a fuel filter, check their oil, look under the hood for leaks etc.. Or even walk around their vehicle! Some of these people could't even change a tire let alone know where their jack is.
So, as for lubricity, us Canadians have you guys south of the 49th over a barrel as diesel fuel here is regulated, mandated to have the "ULSD" and added lubricity.
I suggest you'all come up north buy your fuel here and consume some real beer!
2005 Dodge 3500 CTD QC, 2007 Forest River Cherokee 27RL
CR and Motor Trend both report: My wife says I'm the only one and the best she's ever had.
Your post about sulfur providing lubricity is factually correct and supported by reputable science.
One of the art of forum reading is to not be stampeded by people jumping to conclusions or prescribing expensive "fixes" that may do more harm than good, rather than just doing no harm.
I do not think this is a big deal problem based on the facts to date.
Only a handful of mystery failures, and there are known paths for most customers to get the bill paid one way or another.
Now, it is a bigger problem in that someone from Bosch is probably reading this stuff, and working furiously on finding the problem and a fix... which takes time.
In the mean time, just enjoy your truck and not get hyped up or down!
Oh... note the precautions I laid out in other posts.. No non Ford approved fuel additives, etc.
Common sense protection.
If you are interested in the grapevine... listen closely for the orders for Bosch engineers to board the cattle wagons in Stuttgart to their new job in Siberia.
Then you will know the solution has been found.
edited 03/01/12 02:19pm by NewsW *
