RV.Net Open Roads Forum: Fifth-Wheels: Extended Pin Box Problem
 > Extended Pin Box Problem
jetboater454
Camping or home
Posted: 03/01/12 11:47am Link  |  Print  |  Notify Moderator
Can you do something like this?
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
The Mad Norsky
Yankton, South Dakota
Posted: 03/01/12 11:54am Link  |  Print  |  Notify Moderator
This is not a new problem. Been happening since 2003 when I joined the forum.
Its not so much the truck as it is the length of the extended pin box itself.
Get a shorter, regular length pin box and solve the problem.
The Mad Norsky, Doll, Logan, Korey & Rocky
2011 Ford F350 Power Stroke dually
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
bigjettech
Bartlett,Il
Posted: 03/01/12 04:41pm Link  |  Print  |  Notify Moderator
mpfireman wrote:
As I have always stated, First measure the height of your fivers snout, (not the pin box) from level ground. Then measure the height of the truck's bed rails. You do the math, NOTHINg will change these figures, UNLESS you raise the fivers snout by flipping axles, ETC, or LOWERING your truck's bed rail height. Both methods will cost you $$$. Adjusting your hitch will do NOTHING, but only effect the level of your fiver.
As I have no plans of purchasing a new TV, my 14 year old fiver will do just fine. Knock on wood as everything still works.
And thats exactly what he was referring to, the level of the trailer if you raise the hitch head. If you read the entire thread the op's problem is the pinbox hitting the side rail on the newer trucks with taller bedrails.
2006 Silverado 2500hd duramax 4x4 - with a few mods
2006 Cherokee lite 285b+ 5th wheel
bigjettech
Bartlett,Il
Posted: 03/01/12 04:48pm Link  |  Print  |  Notify Moderator
Not entirely true. The op is referring to clearance problems which started when the truck manufacturers started making the bedrails a few inches taller on the side. I think it was around 2008. A shorter pinbox may fix the clearance issue on the bedrail but it may also cause clearance problems with the cab depending on the truck/camper combo.
restlesswind
Fulltime
Posted: 03/01/12 07:03pm Link  |  Print  |  Notify Moderator
I did OK until I managed to get 90 degrees with the hitch tilted to the side.
(Husky 16K with front to back and side to side tilt.That tilt adds another dimension to the equation.I managed to get both rails.I got rid of the extended hitch head,being as with the longbed truck I didn't need it anyway.
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
okiejoe
Oklahoma City
Posted: 03/01/12 09:35pm Link  |  Print  |  Notify Moderator
You might think about having one of those 5th wheel hauler beds (flat) installed. but its pricey.
Hunter4593
Corpus Christi, TX
Posted: 03/01/12 09:58pm Link  |  Print  |  Notify Moderator
Has anyone tried the PopUp RV5 king pin extender?
2011 Ford F-350 Lariat Crew Cab SRW 4X4 Long Bed
2012 XLR 40X12 5th Wheel Toy Hauler
2006 Jayco 314 BHS Travel Trailer
Crazy Cooter
Redding, CA
Posted: 03/02/12 12:43am Link  |  Print  |  Notify Moderator
Had the same issue with my Dodge.
When I ordered the Morryde, I got the 9" shorter one.
Tony KI6WAO
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2012 Cyclone 300C
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
2008 KTM 525 XC ATV
2008 Polaris 525 IRS
2007 Kawasaki STX12F
2009 Kawasaki 260X
Markrving
Byers, Colorado
Posted: 03/02/12 08:59am Link  |  Print  |  Notify Moderator
Hi there,
Okiejoe is right!
It is hard for me to accept this but that is the only way to do it right. The new pickups are just to high and the bed depth is three inches more. The hitch has to be raised for the pin box to clear the bed rail...Resulting other problems..Will not trade pickups anytime soon. Mark
2010 Montana 3150. Chevrolet 2006 Duramax 2500 long bed 4x4 Michelin. B & W Companion. Goodyear Marathon Chinese Bombs gone, New B.F. Goodrich Commercial LT. Mark Allen
