RV.Net Open Roads Forum: Class A Motorhomes: slide problem
 > slide problem
jmanrambler
Brsitol RI
Posted: 03/01/12 07:39am Link  |  Print  |  Notify Moderator
I just started having a problem with the living room slide on my 2006 HR Vacationer. It has electric slides, the living room slide is a flat bottom with no rollers. When I bring the slide in once it gets to the the final close position the bottom comes in but the top tilts out. I have to grab the top of the slide and pull it in and put the slide lock on. Does this sound like a sheer pin issue? An imput?
Thanks.
2006 Holiday Rambler Vacationer 37sbt Workhorse W24 Chasis
jmanrambler
Brsitol RI
Posted: 03/02/12 08:38am Link  |  Print  |  Notify Moderator
anyone?
chastho
arkansas
Posted: 03/02/12 08:46am Link  |  Print  |  Notify Moderator
If it was a sheer pin the slide would not move. I don't have a HR so don't know how your slide works, it sounds like it may be an adjustment problem.
Clay L
Sioux Falls, South Dakota
Posted: 03/02/12 11:40am Link  |  Print  |  Notify Moderator
As said above if a shear pin breaks the slide won't move. Have you used a ladder and checked to see if there is debris on top of the slide under the topper?
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
wildmanbaker
Kennewick, Washington
Posted: 03/02/12 11:47am Link  |  Print  |  Notify Moderator
Could there be something on the floor, that the slide is running up on, the is tilting the top of the slide out? The other thing that could be causing the top to not come with the bottom, it some type of structural problem with the outside slide wall.
Wildman
chastho
arkansas
Posted: 03/02/12 01:12pm Link  |  Print  |  Notify Moderator
After thinking about your post I think all slides do what you say yours is doing. I don't think you are pulling the top of the slide in, if you are that is a very light slide that is balanced on something. The slides are very heavy and can not be moved by hand.
fcooper
Richmond Hill, Georgia
Posted: 03/03/12 02:20pm Link  |  Print  |  Notify Moderator
The single large slide on my older Holiday Rambler has always had the top edge of the slide contact the coach wall first followed by the bottom being snugged up to the coach wall. From inside it might appear that the top is going out. Could this be what is happening on your coach?
Fred
Fred & Vicki
Richmond Hill, Ga
2000 Holiday Rambler Endeavor/Freightliner/330 Cat
2000 Honda Odyssey toad w SMI Silent Partner braking system
Tire Sentry monitoring system
 > slide problem
