RV.Net Open Roads Forum: Tow Vehicles: So you want a bigger diesel???
Search only in Tow Vehicles
 > So you want a bigger diesel???
Page of 5
NewsW
US
Posted: 03/01/12 07:11pm Link  |  Print  |  Notify Moderator
Will they deny warranty coverage if they find contaminated fuel?
hawkeye-08
Northwest
Posted: 03/01/12 09:01pm Link  |  Print  |  Notify Moderator
probably runs a Bosch HPFP too...
smkettner
Posted: 03/01/12 09:18pm Link  |  Print  |  Notify Moderator
Do you think it will start on the first pull?
675 watts solar
Peg Leg
Anderson, IN
Posted: 03/01/12 10:12pm Link  |  Print  |  Notify Moderator
Eat your heart out, boys. I'm installing that in my alum fishing boat. Trolling for bluegills.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
06 Hitchiker II LS 29.5 FKTS
Yamaha EF3000iSE
retired gadgetman
NewsW
US
Posted: 03/02/12 01:55am Link  |  Print  |  Notify Moderator
There are no internal differences with the Cummins!
JPhelps
SE of Monkeys Eyebrow & Possum Trot
Posted: 03/02/12 06:10am Link  |  Print  |  Notify Moderator
Looks like a 6 cylinder.
2003silverado
Michigan
Posted: 03/02/12 07:08am Link  |  Print  |  Notify Moderator
If I put a K&N air filter on will it improve my milage?
ib516
Up here!
Posted: 03/02/12 07:40am Link  |  Print  |  Notify Moderator
NewsW wrote:
Can you get ARP head studs for it?
Higher volume injectors?
Probably don't need head studs. The engineers that designed that engine likely don't use the junk TTY head bolts - the "elastic bands" of the diesel world.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
mowermech
Billings, MT
Posted: 03/02/12 07:54am Link  |  Print  |  Notify Moderator
That's the "little" one.
The "big" one is 14 cylinders.
BUT, it would take a heck of an overdrive to use it on the highway. It is redlined at 102 RPM!
It isn't much like a Cummins. The Cummins is a 4 stroke cycle engine, this thing is a 2 stroke cycle. There is a separate injection system for upper cylinder lubricant, as well as a common rail type fuel injection.
Apparently, the beast works great for pushing large ships over the oceans!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
NewsW
US
Posted: 03/02/12 08:03am Link  |  Print  |  Notify Moderator
Gotta do the 2,800volt FICM and let the injectors rip!
Page of 5
