RV.Net Open Roads Forum: What can I pull with 2009 4 door4WD Jeep wrangler unlimited
Search only in Towing
Open Roads Forum  >  Towing
 > What can I pull with 2009 4 door4WD Jeep wrangler unlimited
tessa25
Colorado
Posted: 03/02/12 12:11am Link  |  Print  |  Notify Moderator
For mirrors I use McKesh mirrors when I tow my TT.
Palomino Gazelle G150
eric james
Sioux Falls, SD
Posted: 03/02/12 08:25am Link  |  Print  |  Notify Moderator
Alpenliter wrote:
I have found that the short wheel base on the Jeeps make for a squirrley towing platform.
This member's Jeep has a 116" wheelbase. Adequate for towing shorter trailers.
Problem is (as posted already) 3500 lb towing capacity.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
bikendan
Napa, Cal.
Posted: 03/02/12 10:09am Link  |  Print  |  Notify Moderator
even more limiting will be the max tongue weight number.
it would be helpful if the OP listed the year and model trailer.
or the actual specs on it.
the new American Spirit 19QB, is 19' long but has a "dry" weight of 2939lbs. and a "dry" tongue weight of 362lbs.
so, if this is the trailer the OP is looking at, it's too much trailer for the Jeep.
loaded for camping, it'll exceed both max numbers.
* This post was edited 03/02/12 10:18am by bikendan *
Dan- Firefighter, Shawn- Musician/Entrepreneur, Zoe- Faithful Golden Retriever, 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
Slowmover
Corpus Christi, Texas
Posted: 03/02/12 07:36pm Link  |  Print  |  Notify Moderator
Post #1, second picture plus accompanying text.
An eclectic group of Airstreams
Get the right hitch rigging. An Airstream can be pulled by a wider variety of vehicles for a given size and weight than can a conventional box. The JK -- as with other potential tow vehicles -- can do more than most would think.
1990 35' SILVER STREAK Sterling, 9k GVWR
2004 DODGE 305/555 ISB, QC SRW LB NV-5600, 9k GVWR
Hensley Arrow; 15-cpm solo, 25-cpm towing
rightyouareken
Seattle, WA
Posted: 03/03/12 04:36pm Link  |  Print  |  Notify Moderator
Another option might be the Lance 1575. It's designed specifically for TVs with 3500 lb rating. We saw one at a recent rv show and really liked it. The slide out makes it quite roomy.
http://www.lancecamper.com/travel-trailers/1575/
2012 Ford F150 FX4 5.0 3.73 SuperCrew Short Bed
2013 Jayco JayFlight 24FBS, Equal-i-zer 1k hitch
Francesca Knowles
Port Hadlock, Washington
Posted: 03/03/12 05:03pm Link  |  Print  |  Notify Moderator
I like that Lance 1575! Can you use the interior with the slide in?
And do you have a sense of how much weight fresh/waste water, battery, propane, and offered options would eat into the 1,020 pound cargo carrying capacity?
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
Ron Gratz
full time RVer
Posted: 03/03/12 05:41pm Link  |  Print  |  Notify Moderator
This dealer
advertises a well-equipped 1575 which has a "sticker" (image 43) showing
dry weight of 2782# (including propane and factory-installed options)
and a cargo carrying capacity of 520# which, I think, allows for a full load of water.
Ron
Francesca Knowles
Posted: 03/03/12 07:45pm Link  |  Print  |  Notify Moderator
This dealer
Ron
Thanks!
I couldn't find the specs at the link but your numbers sound about right, plus: 50 gallons m/l of wastewater holding capacity- at eight pounds a gallon, that's another 400 pounds.
Remaining carrying capacity is: 120 pounds.
It seems likely that the this'n thats that we all like to bring- like groceries, dishes, pots and pans, clothes, etc.- might meet or even exceed that weight.
Oh!
And if one buys the bike rack, two bikes would weigh SOMETHING...
I wonder if the gross weight numbers are really achievable/practical in the real world....
What think you all?
eric james
Sioux Falls, SD
Posted: 03/04/12 09:39am Link  |  Print  |  Notify Moderator
I think once loaded you'll be too heavy for your Jeep. It will tow it but it will work the Jeep pretty hard. I wouldn't want to be more than 2800 lbs loaded.
