RV.Net Open Roads Forum: Tow Vehicles: Hitch on sprayed bed liner
Search only in Tow Vehicles
 > Hitch on sprayed bed liner
Fish On I'll Get the Net
Dryden, Ontario, Canada
Posted: 03/01/12 06:14pm Link  |  Print  |  Notify Moderator
Does anyone have a 5th wheel hitch installed on a sprayed bed liner? the rv dealer in my area said he won't install a hitch on one.
Thanks
TubaPete
Comstock Park, MI
Posted: 03/01/12 06:21pm Link  |  Print  |  Notify Moderator
We are on our second truck with a sprayed in liner and a hitch. Don't know what the concern is unless its the fact that conceivably the holes drilled through the liner could rust. I have never seen it happen. I'll bet if you look around you'll see a lot of them.
Tuba Pete
Tankcar
Santee, California USA
Posted: 03/01/12 06:22pm Link  |  Print  |  Notify Moderator
Yes! (1994) Line-X, I didn't like the Rhino liner as well as the Line-X. They sprayed bed, sides, and top of the bed rails. They would have done the tail gate to. But! I have a louvered gate. And every 5yrs they will re-seal.
smildrum
Durham,Maine
Posted: 03/01/12 06:31pm Link  |  Print  |  Notify Moderator
Bed liner sprayed in today and hitch being installed tomorrow.
brirene
midwest
Posted: 03/01/12 06:41pm Link  |  Print  |  Notify Moderator
Also had it on a previous truck. No problems.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
uterep
Canada
Posted: 03/01/12 06:43pm Link  |  Print  |  Notify Moderator
I did it the other way around put the hitch in , then removed it and the rails so just holes in the bed , took it got it Line-X'd put rails back in ,re-torque bolts put hitch back in .
been like that for 2 1/2 years no issues at all
Line-X is the best liner without a doubt
restlesswind
Fulltime
Posted: 03/01/12 07:10pm Link  |  Print  |  Notify Moderator
Line-X sprayed in then had hitch installed.I cant imagine any reason the dealer would not do it that way if that is what you asked for.
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
sclark
Minnesota
Posted: 03/01/12 07:13pm Link  |  Print  |  Notify Moderator
I had Rhino on my last truck. Hitch dealer had no problems with the install. Good luck.
2010 Dodge 3500 Crew Cab Cummins
2007 Wildcat 32QBBS
Honda eu3000is Generator
Panadan
Arlington, TX
Posted: 03/01/12 07:15pm Link  |  Print  |  Notify Moderator
I have a RAM 2500 with factory sprayed in liner. Discount hitch does many of the RV dealer installs in this area and they said they have never had any problems installing on the sprayed in liner.
slarsen
Indiana
Posted: 03/01/12 07:25pm Link  |  Print  |  Notify Moderator
Slide-in bed liners are a no-no, as they crush down over time and loosen up. My prior truck had a slide-in, and they had to cut around the rails.
Spray-in liners aren't a problem. That's what I have in my new truck. Your dealer is misinformed, and frankly, if I got such bad information from a dealer, I'd go somewhere else to have the hitch installed. Positioning, under-bed attachments, etc are important and you need to have someone do it that understands what they are doing. I wonder about that dealer.
