Wondering which antennas I should check out. The one that winguard makes says it pulls in reception from 50 mile range. Is this the best? I do not want to pay a monthly satellite bill, but would like some tv.
If you have the Weingard Sensar crank up, they make a $50+- replacement digital antenna that uses the Sensar power supply. I replaced the Sensar with this antenna and had better reception. Did a test for channels before changing and has 1 analog and 2 digital stations. Changed the antenna and had 1 analog and 9 digital. Nothing changed but the antenna. About 15 minutes to replace it. Only "issue" was the leading edge of the longer leg of the antenna mast needed to be bent inward just a bit for the new antenna to crank down.
John and Elaine. Furry ones, Mia, Buddy, Barney and Miss Chevious (MissC for short).
F-250 SD,Excab, V-10
2004 Titanium 26E31DS with Bug Room.
Know guns, know safety, know peace. No guns, no safety, no peace.
thanks, Patricia
You can check out the Jack Digital antenna also, especially if you're starting from scratch.
If you already have a crank up Wingard, all you may need to do is get their Wingman add on.
Erroll, Mary, Duffy the Badger Dog plus "Ollie"
2009 HiLo Towlite 2209T
2005 F150 Supercab 4x4, w/ 5.4L
Depends honestly, but I just installed a powered TV antenna of the 'ufo' style on our boat. Put it right on the mast, I have a regular powered antenna for the camper that gets clipped to the roof before we 'pop' it up.
Keep in mind that the higher you have your antenna the better reception you're likely to get.
The higher the decibel gain rating on the antenna the more 'powerful' it will be at getting a signal, though if there is no signal within a few miles you aren't going to get diddly.
Any day enjoying the great outdoors beats any day enjoying your 8x8 office cube!
I have a boomerang shaped antenna that came with my rv. I think Ive heard them referred to as bat wing antenna. I assume being that my Vista Cruiser is so cheaply made, the antenna follows suit. I have to move this antenna to put solar panels up, and so I thought maybe a quality upgrade would be a good idea.
Thanks everyone, and anyone else please feel free to pipe up and give your oppinion. So far the winegard iv looks like the best one. I think it comes with the amplifyer someone mentioned...
An amplifier is needed at extreme ranges to make up for the consumer grade receiver at the other end and also cabling losses.
If you have a permanently installed antenna outside the RV, it might be tricky to install the amps that is antenna mounted (best sensitivity because they get the signal right there).
Alternative is to amplify the signal right after it enters the rig.
In any case, don't scrimp on cabling --- top quality (not RV or cheap home grade) cabling is essential to reduce losses.
The amps will cost a bit of power (a few watts, but can be as much as 5 or 10) to run -- note that in your budget.
My preferred supplier for high quality broadband amps:
http://broadbandamps.com/dropamps.htm
The VSMA-601C will work fine --- it is by Viewsonics, a division of Emerson Electric and is about $50 list.
Similar ones from Motorola is known to be reliable.
edited 03/02/12 12:04pm by NewsW *
