RV.Net Open Roads Forum: Truck Campers: Routing of lines for air bags
 > Routing of lines for air bags
John3872
Iowa
Posted: 03/02/12 11:18am Link  |  Print  |  Notify Moderator
tkcrawford wrote:
My air bag fittings are behind the fuel filler door. Keeps them clean and easily accessible.
x2
Nice and easy place to get to.
2003 Chevy 2500HD Duramax Crew Cab
2009 Palomino Sabre 30RLDS
Reese 16K Fifth Wheel Slider
Yamaha ef2400is
Gripnriprod
Alaska
Posted: 03/02/12 11:20am Link  |  Print  |  Notify Moderator
While our installation includes a compressor and remote controls, I had a fitting installed under the fuel door.
'11 GMC 3500hd SLT DRW D/A 4x4 Spray-in, Air Bags w/comp & controls, TL, Superhitch, 48" Supertruss, 9.5t Warn, front rcvr, Fox Shocks, '11 AF 1140, DB, AC, Gen, Solar, Thermal Windows, Wardrobe, Rear & Side Awnings, 18' Lund/40hp Honda 4 stroke
Pete_k
Stantonville Tn
Posted: 03/02/12 11:58am Link  |  Print  |  Notify Moderator
That is the best spot for them. Out of the weather and also easy to get to. Plus don't have to get down on one knee to air them up or down.
Pete
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
bka0721
Republic of Colorado
Posted: 03/02/12 12:03pm Link  |  Print  |  Notify Moderator
I installed mine right where I have my level gauges attaced to my Truck Camper. I use my airbags to do the "Final Fine Tuning" of leveling my truck canmper. That way I can stand in one place and watch the Bubbles move left or right, front of back, where needed.
I also did not mount an air compressor, as the type of compressors that are available are not very dependable IMHO. I had two fail, in previous truck/race trailer combinations, as well as two other failures with other racers in our team trucks. I have an onboard compressor that I use for many other things, bike tires, float tubes, rotating truck tires and filling them, checking trailer, Motorcycle, truck tires, so that is what I use.
b
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
wcjeep
Tacoma, Wa
Posted: 03/02/12 12:23pm Link  |  Print  |  Notify Moderator
Avoid the rear of the truck with a TC. Both of mine are located in the rear driver wheel well. I also located an air chuck near the air bags from my on board Air Zenith compressor.
kerry4951
East Central Pennsylvania
Posted: 03/02/12 12:25pm Link  |  Print  |  Notify Moderator
fjrjohnny wrote:
Where did you mount the compressor?
Under the back seat. Picture is with the bottom seat cushion lifted up. Wanted mine out of the weather.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
rehoppe
Denver & Nathrop Colo or somewhere else
Posted: 03/02/12 12:46pm Link  |  Print  |  Notify Moderator
If you want to help eliminate 'sway', plumb them separately as previously noted. Plumbed to one fitting promotes a smoother ride Maybe, but also contributes to sway and waddle.
Hoppe
2011 Dodge 1500 C'boy Caddy
2000 Jayco C 28' Ford chassis w V-10 E450
Doghouse 36' or so Trophy Classic TT
kcabpilot
CA
Posted: 03/02/12 12:58pm Link  |  Print  |  Notify Moderator
That sounds like the best idea. Definitely do not put them at the rear plate if your camper is longer than 8 feet. I put mine just aft of the rear wheel pointing down from the fender so that I could see the height at each wheel but it requires taking your hose or pump to the other side. Eventually, after about 12 years, I installed a dual gauge controller. It's not a necessity but it certainly is nice to have.
One obvious warning on the routing: Make sure the lines don't contact or cross any semi-sharp edges such as the bed seams or such. It will take a few years but they will eventually wear a cut into the plastic line and create a leak.
Ask me how I know.....
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
fjrjohnny
Northern WI
Posted: 03/02/12 03:23pm Link  |  Print  |  Notify Moderator
Great responses and suggestions. Thanks to everyone who chimed-in!
Gale Hawkins
Murray, KY
Posted: 03/02/12 07:01pm Link  |  Print  |  Notify Moderator
kerry4951 wrote:
Why dont you install an in-house air compressor and switch panel to operate from the convenience of the cab. They sell kits with 12 volt compressor and switch panel. Make sure to get the double switches so you can operate the bags separate from each other. A little more work to install but well worth the convenience.
Nice set up.
Manual set-ups especially with no in-cabin gauges are risky we learned the $$$ way in our MH.
