I'm new to RVing and just purchased a 2000 Coachman Class C 31' E450 with a V10. The old owner gave me a Demco Excali-Bar and a break buddy. I own a 2005 Chevy Tahoe 4x4 and from doing my research found I can tow this four down. My concern or question I have, is the Tahoe to heavy for the V10. I also found that the old owner had a class II receiver put on and it is rated at 3500 lbs. Can I change the receiver out to a Class III or IV and be good to go?
Thanks for your help!
2000 Coachmen Leprechaun 314ss
2000 Mastercraft Sport Star 19
2004 Honda CRF230F
maybe. tow weight is not just about the hitch. it's about the frame, engine torque, tranny ratio, etc. if all you needed to do to increase tow weight was to change out the hitch then we'd all have Class IV (10K) hitches installed. if you swap out the hitch you likely can tow the Tahoe but can you tow it *safely*? i'd place a call to the mfg. and speak with someone there about this.
73,
rich, n9dko www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
I believe the engine will handle it, but you may have issues with the rest of the RV? What are the weight numbers for towing the Tahoe? The V-10 is a very strong engine (just short of a diesel, in my book, though you'll run at a higher RPMs to get the most of that power).
The hitch can be changed out, but you will want to find out if the chassis can handle the larger receiver. Probably best to contact the mfgr, though most hitch mfgrs will have books telling which hitch will fit where.
I have a larger hitch (5K pound) on the back of my 30' "C", with the V-10, though at this point, I haven't towed anything yet.
Do a bit more research.....and good luck.
Bill & Claudia / DD Jenn / DS Chris / GS MJ Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293 The Pets
Thank you for the email inquiry. The motor home in question can tow up to 5000 pounds with a receiver hitch rated at 5000 pounds - you will want to verify a 5000 pound hitch was installed versus a 3500 pound hitch (you can upgrade from 3500 to 5000, but not higher). I believe the Tahoe is pretty darn close to the 5000 pound figure, verify weight to be sure.
I found this info below on the 2005 Dinghy Guide
Model Base Curb Weight
Tahoe/Yukon 4WD 5,050
So if I don't put anyone or anything in it I might be OK Not sure if I should have it weighed some where.
I'd have it weighed.....yes, it's only 50 pounds, and I'm sure that there are safety room in that 5000 limit, but if something were to happen, you might be held responsible, for knowing that you were over the limits.
If you weigh the unit, and you are under 5K, even 50 pounds under, you will be OK. And I still think the RV's V-10 engine, if it's tuned up, should handle the load.
I'm pretty sure that Tahoe will weigh over 5K. You should still be under the chassis GCWR of 20K. Your biggest issue with that rig will likely be unrelated to towing. You are very likely close to your rear GAWR without anything loaded.
I had a 30 foot H R with the V10. We put a clss 1V hitch on and upgraded the transmission, Towed 7500 lb boat ( electric over hydraulic brakes)--no problems over both American and Canadian Rockies to SE AK. But you have to do the appropriate mods, and have someone who know what they are doing. The engine was fine. Enough power--not like a diesel'
Bob and Marie Austin
Angel miniature poodle
2007 Holiday Rambler Ambassador 40 PDQ
Toad 2012 GM Yukon XL 4 x 4
I talked to a local shop and they seemed to think it would be no problem. Put a bigger hitch and weld a couple plates on the frame extension towards the rear where there is a notch in the frame. He said the engine would be no problem but I would need to leave the overdrive off on the transmission when towing it so the transmission wouldn't need to keep shifting. I really didn't want to purchase another vehicle because I really won't need to tow a vehicle with me most of the time. It would be for just once in a while, for the most part I see towing the boat and a motorcycle trailer for the trips. Just thought it would be a nice option because I already have the tow bar and break buddy that came with the RV when I purchased it.
gmschmitz wrote: I talked to a local shop and they seemed to think it would be no problem. Put a bigger hitch and weld a couple plates on the frame extension towards the rear where there is a notch in the frame. He said the engine would be no problem but I would need to leave the overdrive off on the transmission when towing it so the transmission wouldn't need to keep shifting. I really didn't want to purchase another vehicle because I really won't need to tow a vehicle with me most of the time. It would be for just once in a while, for the most part I see towing the boat and a motorcycle trailer for the trips. Just thought it would be a nice option because I already have the tow bar and break buddy that came with the RV when I purchased it.
is the local shop going to stand behind their words when/if you have a problem related to the extra tow weight. strongly suggest before you do anything that you speak with someone at Coachmen and get their take. at least then you'll be making an informed decision.
I did talk to someone at Coachmen and they told me the coach was rated to tow 5000 lbs. I will have the Tahoe weighed before I make any decisions worse case the wife will need to follow me when we need it.
