RV.Net Open Roads Forum: Tow Vehicles: 2012 Chevrolet Brake Wiring
Search only in Tow Vehicles
 > 2012 Chevrolet Brake Wiring
Luke Porter
Not on the road :(
Posted: 03/02/12 11:36am Link  |  Print  |  Notify Moderator
I have a 2012 Chevy with the built-in brake control. Is everything wired--brakes, battery, lights---and ready to go?
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
ksss
Eastern Idaho
Posted: 03/02/12 01:26pm Link  |  Print  |  Notify Moderator
Yes as long as whatever you hooking up to requires the standard RV style plug your good to go.
2006 GMC 3500 CC 4X4 D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2005 GMC 5500 CC 4X4 D/A
2012 Chevy 2500HD 4X4 6.0 3.73
APT
SE Michigan
Posted: 03/02/12 01:35pm Link  |  Print  |  Notify Moderator
My 2011 Burb was as was my friends 2012 Silverado 3500.
2012 VW Passat TDI
Turbo Diesel Dude
Green Mountain, NC
Posted: 03/02/12 02:13pm Link  |  Print  |  Notify Moderator
Make sure that the 30amp fuze is installed for your trailer charging system
charles weidman
dmax_83
SE WIsconsin
Posted: 03/02/12 04:24pm Link  |  Print  |  Notify Moderator
My '11 was good to go.
1998 Jayco Eagle 302FK (Honda EU3000is)
2011 GMC Sierra 2500HD 4x4 Duramax/Allison
2003 Honda Aquatrax F-12X Turbo
Delaine and Lindy
Linden Tn. (The View)
Posted: 03/02/12 07:35pm Link  |  Print  |  Notify Moderator
I had a new 2011 Chevy and the 2012 and everything worked. I do have a CM hauler bed on the 2012 Chevy 3500HD DRWs and everything was plug and play on the CM hauler Bed install... Everything worked on every 3500HD DRW's I have owned prior to the IBC except on the 2005 and the 2007 I did have to connect one wire, which was very simple... Good Luck. Happy Trails....
2012 Chevy Silverado 3500HD DRW's LTZ ******Traded******
Trailer Saver Air Ride (SOLD) (Sold)
2010 Mobile Suites 38 RSSB 3, with vanity slide (SOLD)
"Montana" our Sweet Furr Kid
12/21/10 "RIP" miss you!!
We are BLESSED!!!!
kabbro
Superior, WI
Posted: 03/03/12 08:41am Link  |  Print  |  Notify Moderator
You'll probably have a problem if your trailer has Dexter electric over hydralic brakes...I was in the middle of this dilemna a E/H brakes (confirmed by both GM and Dexter)...there are work-arounds but I went with taking my Dexter Predator controller from my old truck and having it installed on the new truck...was an irritant that Chevrolet hasn't solved this problem...the IBC works with Dexter on the Ford and Dodge.
Kenneth A Bromen
kabbro
Superior, WI
Posted: 03/03/12 08:44am Link  |  Print  |  Notify Moderator
don't know why a couple of sentences on the above post didn't appear. "I was in the middle of this dilemna a year ago with a new 2011 Chev Duramax and a trailer with Dexter E/H brakes. The IBC doesn't work with Dexter E/H brakes (not sure if there are other E/H brake systems and whether the IBC would work with a non-Dexter, or not.
dmax_83
SE WIsconsin
Posted: 03/03/12 09:02am Link  |  Print  |  Notify Moderator
^^^ Here is a LINK to a topic on DP that addresses the issue ^^^
MM49
Brighton, MI, USA
Posted: 03/03/12 09:17am Link  |  Print  |  Notify Moderator
You will need to change the trailer side 7 pin RV connector. All of the OEM truck manufactures have TSB, s recommending this. The twin contact terminals used by most trailer manufactures doesn't work well the truck receptacle. Just change out the trailer side connector to a Pollack flat blade style and you will have no intermittent problems.
MM49
