jjj
Lancaster,Ca.U.S.A.
I could not find anything on the search about this. I have searched the internet widely about ladder bars for a 2 wheel drive Ford F-350 dually and cannot find them,only for 4x4's. I have some axle rap when starting off with my 13000 lb fiver and wanted to add some ladder bars to help with it. Has anyone out there put some on their 2wd truck and what brand. It is amazing the amount the srings roll when accelerating with that much weight in tow.I saw a bunch on you tube.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
tvman44
Southwest Louisiana
When I was involved in drag racing we called them traction bars.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
ib516
Up here!
Shouldn't the ones for the 4x4s fit? I mean, aren't they the same from the cab back?
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
LIKE2BUILD
Mt. Zion, IL
How long do you plan to keep this truck? The reason I ask is there are companies that offer complete rear air suspension systems. There are a couple that use the existing spring hangers for the trail arms. My thought is rather than put a band-aid on the issue, why not go to a full air system a fix the wrap problem for good? Of course this will be costly which is why asked how long you'll keep the truck. If you keep it a long time the air kit makes sense. If you're only keeping it a couple years it's not worth the cost.
On edit, I found a link to one of the systems I was thinking about.
AirBagIt.com 4-Link air bag suspension
KJ
last
edited 03/02/12 07:45pm by LIKE2BUILD *
View edit history
'02 Jayco Qwest 324G
'04 Chevy 2500HD CrewCab |6.0L|2X4|4.10:1 | Eaton Posi-Trac
Curt MagnumV receiver
Eaz-Lift Hitch with Reese Dual Cam
2000 Crownline 205BR
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (12, 6, & 4)
1 forgiving wife!!!
Engineer9860
Eagle Scout dad
Not trying to be a smarty britches, but if you are using the truck within the design parameters of the OEM, and it appears you are, why not let the suspension react as it was designed?
In Memoriam: Liberty Belle
MudChucker
Niverville Manitoba
are you looking for ladder or traction bars ?
the 2 are very different. Very likely you only need traction bars.
Ladder Bars,
Classic Traction Bars,
a better version of traction bars more commonly found on trucks,
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
JPhelps
SE of Monkeys Eyebrow & Possum Trot
That bottom one is actually a cheap piece of junk and will end up either breaking off or bending the frame and then breaking off. That C channel frame is not design for that kind of stress and would need to be at the least closed up for several inches either side of the mount. The bar and joints are cheap tractor hitch bars and wear quickly and loosen up with mucho slack.
Ladder bars are an even worse solution for a non existent problem for a truck used inside its design parameters.
Leave the suspension alone is my best advice.
edited 03/02/12 05:37pm by JPhelps *
Wills250psd
walnutcove NC
jjj wrote: I could not find anything on the search about this. I have searched the internet widely about ladder bars for a 2 wheel drive Ford F-350 dually and cannot find them,only for 4x4's. I have some axle rap when starting off with my 13000 lb fiver and wanted to add some ladder bars to help with it. Has anyone out there put some on their 2wd truck and what brand. It is amazing the amount the srings roll when accelerating with that much weight in tow.I saw a bunch on you tube. Are you having vibration when taking off if so there is a tsb out that will shim down the carrier bearing and correct it. what year do you have and is it crew cab long bed. its most common in these models.
sc3283
St Louis
jjj. your type truck us widely used for towing all sorts of trailers and loads. Being into racing and having tons of buds with similar trucks...none have ever complained or had issues with spring wrap up. Are you sure your having a "wide up" situation and not feeling something that is considered normal or have something else not proper? Are the rear shocks worn out or leaking? They control axle movement and could possibly create an abnormal feel or movement pending how hard you stab the throttle on take offs...just some ideas for you to consider
04 D-Max Crew Dually
96 Monaco Dynasty 36'
Turtle n Peeps
California
If you think that truck rides rough now just slap a set of ladder bars on it.
Both of the race cars I have driven had ladder bars on them with full floating bird cages on them. Dump trucks I have driven had better rides.
outside the fire"
