justtrippin
Yakima
Hey all i was wondering if any of you have built a flag pole for your tt? I"m looking for some idea"s i would like to some how mount it to the front of the tt. it has to be light wt. and removable any idea"s? mount to the frame? thanks for the input. if you have picture"s that would be great to see.
Wiscampsin
Wisconsin USA
Here's a popular PVC one doesn't mount to your TT but it's worth a look. Just pound a piece of rebar in the ground and it'll rotate with the wind.
I suppose with a few adaptations you could mount it to your TT.
Link:
http://www.missouriscenicrivers.com/PVCflagpoleplans.html
2013 Palomino Sabre 34 REQS-6
http://s1340.beta.photobucket.com/user/W........6?&_suid=1357224714962013706578115184365
Old-Biscuit
Across the USA
Flag Pole Buddy
Mounts, poles, kits........
afraid of bears
Prince George Area
I use a couple of those long telescoping fiberglass poles.
Clicky
I attached a footlong piece of pvc pipe to the side of the tongue jack. The pole slides right in. To stop any rattling, a piece of that insulation that you put on your pipes works well.
anaro
Mebane, NC
A quick google search found this I don't know if you could find a way to make that work or use it as a template. We have one of the telescoping one's on the ladder now.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
pigman1
Delaware
Lots of these available. Just pick one you like, but be careful when you use it. We had a cat at a NASCAR race a while ago who put his pole up under a high voltage line. The pole didn't come in contact with the wires, just somewhat close. Result: One crispy critter and a few others badly burned. I knew the EMT's who responded. Not at all nice. Just be careful.
John
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Street Atlas USA Plus
LarryJM
NoVa
made the following out of a 2' piece of PT decking, a couple of pieces of 2" flat stock for stiffness and a 2" pipe floor flange. I then can screw in a 24" piece of pipe into it and insert my homemade flag pole which is just one of the expanding pool cleaning extending poles. I have a hole in the pipe and thru the flag pole where a thumb screw and wingnut go to hold the two together. Been using this for arounf 14 years.
Pic of pole in the holder:
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
JoyceandSteve
Houston, Texas
Wiscampsin wrote: Here's a popular PVC one doesn't mount to your TT but it's worth a look. Just pound a piece of rebar in the ground and it'll rotate with the wind.
Link:
This is what I made. Looks great, easy to make, and easy to transport.
Steve & Joyce
2011 Chevrolet 2500 Z71 4X4
2013 Montana High Country 343 RL
1996 Celebrity 200 Boat
2000 Yamaha 1200 LTD Waverunner
2012 Ford Mustang GT (Mama's ride)
Vítejte na víkend doma a Steve Joyce
mowermech
Billings, MT
I went to Harbor Freight and bought their telescoping flagpole.
then somebody told me the joints have a tendency to slip.
No big deal, if it does I'll drill holes and put pins in it to hold it!
I intend to use it for both flags or amateur radio antennas!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
nevadanick
Elko, Nevada
i got mine here http://www.polesandholders.com/home.phpe great service and price is right.
