RV.Net Open Roads Forum: Travel Trailers: Towing Caravan(Travel Trailer) through Soft Sand
 > Towing Caravan(Travel Trailer) through Soft Sand
RobertRyan
Australia
Posted: 03/03/12 03:47am Link  |  Print  |  Notify Moderator
I Not aware if people do something like this in the US, common here though. Do you know anyone or yourself that has done this on the beach or in the desert?
Caravan(Travel trailer) in Soft sand on the beach
Michael in MN
MN
Posted: 03/03/12 05:57am Link  |  Print  |  Notify Moderator
Oceano Dunes, CA?
LivinLite Camplite 16BHB
2011 Ford F150 EgoBoost
Mark and Linda
Smyrna, Tennessee
Posted: 03/03/12 06:29am Link  |  Print  |  Notify Moderator
I bet if they made a dead stop they couldn't get started again. Then it would be get out the planks and try to recover...it was remarkable though.
agesilaus
North Florida
Posted: 03/03/12 07:12am Link  |  Print  |  Notify Moderator
I could not tell if they de-aired the tires or not, which is the usual tactic. They'll reduce the pressure way down to 10 or 12 psi. Look at the ground clearance on that TT. I've seen other videos of the Aussies towing that brand of TT up rock covered goat paths with a 20% grade. I think it must be a off-road trailer.
Glendale Titanium 29E34TS fifth wheel
PullRite OE Series Super5th 18K
Superbumper
christopherglenn
a little over an hour from Yosemite
Posted: 03/03/12 12:07pm Link  |  Print  |  Notify Moderator
2.5 ton trailer, thats 5000 lbs. Try it with a 9 to 10k TT and lets talk.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
BarneyS
S.E. Lower Michigan
Posted: 03/03/12 12:32pm Link  |  Print  |  Notify Moderator
One of our members, Burbman, does it all the time., and with a large trailer also!
Let the talking begin!
Barney
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
CakeHenn
Temple, TX
Posted: 03/03/12 12:50pm Link  |  Print  |  Notify Moderator
My tundra has a bit of envy for the diesel Toyotas they have available down under. Wish they offered them here!
TT: 2013 Jayco Eagle 314
Truck: 2006 GMC 2500HD Duramax
Duck Gun: Benelli Super Black Eagle II
agesilaus
North Florida
Posted: 03/03/12 12:54pm Link  |  Print  |  Notify Moderator
Yeah he airs down the tires. The off road driving book I just read said that you should measure the sidewall height at full pressure then bleed off air until you reduce that to 75% of the full pressure height but never below 10-12 psi. Drive dead slow and that will prevent tire damage.
Of course you'll need a way to air up the tires when you get off the sand, don't drive the deflated tires on pavement more that a few feet.
6.7 tow rig
kentucky
Posted: 03/03/12 01:14pm Link  |  Print  |  Notify Moderator
Think all the stuff stays in the cabinets?
2012 Dodge Ram 2500 Cummins 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
RobertRyan
Australia
Posted: 03/03/12 03:13pm Link  |  Print  |  Notify Moderator
Quite common here, generally 7,500lb to 8000lb + Off Road Caravan
Yes the Diesel SUV's pull very well over sand etc.
More like close to 8000lbs.
