RV.Net Open Roads Forum: Fifth-Wheels: Between the wheel chocks.. use when jacks?
 > Between the wheel chocks.. use when jacks?
KampingKris
Folsom, CA USA
Posted: 03/03/12 09:09am Link  |  Print  |  Notify Moderator
Is there any reason one can't use the chocks between the wheels when raising or lowering the front legs? Does it bind the axles?
We like the extra stopping power while hooking up but wanted to make sure it is okay to do it that way
KampingKris & FiremanSteve
Jada - American Eskie princess
2003 GMC Sierra 3500
2006 Alpenlite Limited 34RLR
2010 Polaris 850XP
2008 Polaris RZR
garysol
Avon Ohio
Posted: 03/03/12 09:12am Link  |  Print  |  Notify Moderator
I put my x-chokes between the wheels before I do anything else. I don't see how it could cause any issues.
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
Old-Biscuit
Across the USA
Posted: 03/03/12 09:13am Link  |  Print  |  Notify Moderator
First thing.......install wheel chocks
Last thing........remove wheel chocks
Make those two steps routine.
Wheel chocks should be installed to stop rig from moving when unhitching from truck
Wheel chocks should be last item removed/stored after hitching up and doing a pull test.
korbe
Northern California
Posted: 03/03/12 09:30am Link  |  Print  |  Notify Moderator
I set my chocks right after I've got the wheels set. Now if I was to see that I would need to raise the front a lot, I may wait and set the chocks right before I disconnect the truck.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
larry barnhart
wenatchee. wa usa
Posted: 03/03/12 09:38am Link  |  Print  |  Notify Moderator
I wait for the tires to cool down before the chocks that I built years ago are installed. When we unhook the trailer does not move so no reason for us to do it different. Same when hooking up the trailer does not move.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Mile High
Denver, CO
Posted: 03/03/12 09:56am Link  |  Print  |  Notify Moderator
No problem at all. My rotochoks go in first thing.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
Pete_k
Stantonville Tn
Posted: 03/03/12 11:30am Link  |  Print  |  Notify Moderator
Here's a reason to make sure tires are not able to move. RV death It may never happen to us, but do we want to chance it. It was so sad, But something that is done each day.
My heart went out to this man, the day I heard about this. And Told my self. We would never allow this to happen when we move to a 5th Wheel.
* This post was edited 03/03/12 11:36am by Pete_k *
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
luvglass
Milwaukee
Posted: 03/03/12 11:59am Link  |  Print  |  Notify Moderator
First on / last off. Never had a problem with raising or lowering the front jacks.
Fred Wishnie
2006 Carriage Cameo 35KS3, 2006 Ford F350 diesel dually, fulltimer
See our blog at http://www.mytripjournal.com/wanderingwishnies
NorthernLimits
Michigan
Posted: 03/03/12 12:04pm Link  |  Print  |  Notify Moderator
Something is totally fishy about that report.
Old-Biscuit
Across the USA
Posted: 03/03/12 01:08pm Link  |  Print  |  Notify Moderator
What's fishy is the typical lack of reporting done any more. According to later/follow up reports:
The husband was out of the truck checking the hitch, truck was in neutral & no wheel chocks on trailer......truck/trailer began rolling, wife ran towards truck but was struck by trailer door that knocked her down and then she was run over by trailer as truck/trailer jack-knifed.
Point is......if trailer wheel chocks had been in place truck/trailer combo would NOT have rolled away.
1st on/last off....K.I.S.S.
