tcoop4899
home
I have installed a swing arm tv mount in the bedroom and i am now looking for suggestions on how to secure it while we are towing from point "a" to point "b".Im a "handyman" type person so constructing is not a problem if necessarry. I just cant seem to get my brain to come up with any ideas. Thanks in advance for the help.
TnT Cooper
2012 Palomino Puma 25-RS
2006 F150 Supercrew
8iron
Canada
Any pics? How big is the TV and is it lcd (lighter) or Plasma (not light). How did you mount the swing arm?
2011 F250 Lariat FX4
2011 Sunset Trail Reserve 29ss
docj
Fulltime--Home is where we park it
We have our living room TV mounted on a swing arm. We use an "elegant" solution consisting of brass hooks mounted to the cabinet on either side of the TV with a "designer" bungee cord hooked between them. Simple, cheap and works well.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
Old-Biscuit
Across the USA
I installed a swing arm TV mount in bedroom......then for travel I secure the TV and mount with a 1" adjustable buckle strap. Strap goes thru a simple bracket that is screwed onto bottom of cabinet and round swing arm...cinch it up...done.
Been that way for 4yrs.......travel every week. No problems.
Similar to this bracket but metal....got it at hardware store
youth4him
Belgrade, MT
A bungee cord will do wonders, or the buckle type. You can actually do that around the arm itself in it's "folded" position. I also throw a bed pillow on the screen under the bungee on mine for extra protection.
One thing to think about, and I've learned the hard way...the force on an arm mount in a TT is tremendously more than one in a stationary room, so keep that in mind.
KD
Trip of a Lifetime Blog - 12000 Miles, 100 Days, 34 States, 4 Humans, 1 Mini Daschund...FUN!
2007 GMC Yukon XL Denali - 6.2L, 6-speed
JRS & B
Florida/Michigan
A little late in the game for this, but Camping World does sell a locking cantilever bracket - they run about $65 for the swing arm and pull chain lock. It happens to be the exact unit that came with my trailer and it does work just fine.
Artemus Gordon
Redding California
I took "industrial Velcro" glued to back of TV and did the same to the wall. It's only visible on wall when we use the TV. Holds very well with added superglue for more strength. Next owner gets the TV so they should not mind. Note I used the wide Velcro.
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
phillyg
Front Royal, VA
docj wrote: We have our living room TV mounted on a swing arm. We use an "elegant" solution consisting of brass hooks mounted to the cabinet on either side of the TV with a "designer" bungee cord hooked between them. Simple, cheap and works well.
x2, and you can also use a strip of Velcro from one hook to another.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
Kanyonkitty
Gerrardstown, WV
I just take a strip of velcro, one side with the teeth and one side with the loops, put about 6 inches of each piece together, this will give you one long piece and attach it to the wall behind the mounting bracket (you might even be able to use the same screws), then attach the bracket. Now all you have to do is wrap the velcro around the TV and it is secure.
Deep wedgewood blue '99 7.3L PSD F-350 Super Duty crew cab long bed dually or wedgewood blue '97 F-350 7.3L PSD crew cab longbed SRW, Member: Sunlineclub.com Rescue a retired Greyhound, greyt calm low maintenance traveling companions
dewatkins
Dallas Texas
I take my bedroom off and lay it on my air bed has worked for me many miles never even moves. The one in the living room came with a set of plastic hooks and the web belt just unclip the snap when on site.
