RV.Net Open Roads Forum: Truck Campers: dually swingout brackets
 > dually swingout brackets
campn4walleye
Central WI
Posted: 03/03/12 01:59pm Link  |  Print  |  Notify Moderator
A unit that we are considering doesn't have dually swingout brackets. Are these relatively easy for the dealer to add? What is the average cost to have this done? Should we ask for it to be included in the deal or just expect to pay for it extra?
2011 Adventurer 910FBS truck camper,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD,4x4,LB,CC,auto,3.73 axle,General 17" on/off rd
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
Eycom
32043
Posted: 03/03/12 02:06pm Link  |  Print  |  Notify Moderator
Dually swing-out brackets
RVn Full-time
Gary Gadget
Windsor, WI
Posted: 03/03/12 02:09pm Link  |  Print  |  Notify Moderator
Swing out brackets are a "bolt on item" The existing holes are used for the camper and for the jacks. I purchased swing out brackets on line at cheaper than I could get from my dealer. Either way you can ask what your dealer will charge and what you can get on line. The front jacks are all you need the swing outs for. Some campers come from the factory with swing out brackets on the camper, as part of the cost of the camper. Check with your dealer first.
FF1063
NY
Posted: 03/03/12 06:01pm Link  |  Print  |  Notify Moderator
My TC came with them from the factory, but they are easy to add. Adventurer is using the HappiJac elec jacks. You will need large swing out plates with the Ram DRW. Which swingout bracket to buy depends on the Jacks you get. The pic is what I have on my HappiJacs, so you can see just how the part attaches/works. Even with the wide swing out, I only get about an inch or so clearance on a DRW
[image] [image]
The earlier link will lead you to what you need, just depends on what Jack you are trying to extend.
* This post was edited 03/03/12 06:19pm by FF1063 *
98' Ram 3500 DRW / 05' Arctic Fox 990
campn4walleye
Central WI
Posted: 03/03/12 06:58pm Link  |  Print  |  Notify Moderator
thanks FF1063, that's the type of info we're looking for. Are not all Happijac jacks not the same? Do I need to call the company or dealer and find out specific info? I'm trying to save everywhere I can. Savings have to go to gas.
ADC0731
Bracebridge ON
Posted: 03/03/12 08:00pm Link  |  Print  |  Notify Moderator
Most dealers probably have some used brackets in the back somewhere. And it's not like they go bad. We were offered used brackets for $145 - but eventually they got thrown into the deal. When installed, they looked just like new.
And to those who will ask 'why do you need swing out brackets when you don't have a dually?', we bought a 7' wide Lance and needed the brackets to clear the quadrasteer flares on the truck - 6" wider than the standard truck.
2003 Silverado 1500HD with Quadrasteer
2005 Airstream 30 Classic Limited
2012 Lance 825
FF1063
NY
Posted: 03/03/12 08:01pm Link  |  Print  |  Notify Moderator
I believe all square tube HJ's use the same bolt configuration and same bracket. I don't think the brackets are common to Attwood or Rieco brands, but someone else that would have to write in on that to clarify for certain.
When I bought my TC's from dealers, the LPG, battery, truck wiring, swingouts, prep, etc were all part of the negotiated price. I doubt you would really save anything as getting the TC on the truck and sending on your way is all part of the deal, and they will see you have a DRW.
Hey there
Pendergrass, GA
Posted: 03/03/12 10:51pm Link  |  Print  |  Notify Moderator
Hi,
Before you buy any swing out brackets, determine how much distance between the jacks you will need to clear your dually fenders. Then you need to find out how wide the space is between the jacks on the TC you are considering. The difference between those two measurements is how much distance the dually swing out brackets must give you. All TC's are not the same width and I have seen different width dually brackets.
Kurt
2001 Silverado 3500 DRW CC LB 6.0
1993 Lance Squire Lite 150 (8'6")
2001 Fleetwood Caribou 11J (11'6")
campn4walleye
Central WI
Posted: 03/04/12 09:05am Link  |  Print  |  Notify Moderator
Kurt,
We know the TC is 96" across. Do we measure the width of the fenders? The TC has Happijac jacks and their swing out brackets are 4.5" if I remember correctly. Thanks for the info. Would the company have the info on the part # needed for that specific TC?
Hey there
Pendergrass, GA
Posted: 03/06/12 11:55am Link  |  Print  |  Notify Moderator
Hi again,
That is a nice wide camper. If the swing out brackets do 4.5 inches each, that would be great. Yes, measure the width at the widest part of the fenders to determine your needs. I do not know about fitting/finding brackets to fit a specific TC. A call to Happijac or Lance might answer that question. They may all use a standard bolt configuration. Good luck!
Kurt
