RV.Net Open Roads Forum: General RVing Issues: 92J or 3X18W Light bulbs?
 > 92J or 3X18W Light bulbs?
FinLee
108 Mile Ranch, BC
Posted: 03/03/12 02:25pm Link  |  Print  |  Notify Moderator
Does anyone know what type of bulb is a 92J or 3X18W? I looked at mine and read this is the type to replace with but cant find any info on them. I wanted to replace with leds but need to find a reference numbrt that matches, any info would be great.
2oldman
Winchester WA
Posted: 03/03/12 02:30pm Link  |  Print  |  Notify Moderator
It doesn't matter, there really isn't any reference as there are thousands of LEDs which will work, but maybe 3 you'd actually be able to see with.
All you really need is the type of base, and the voltage.
FinLee
108 Mile Ranch, BC
Posted: 03/03/12 02:38pm Link  |  Print  |  Notify Moderator
the bulb itself slides straight out and is all glass with a wire on each side of glass base, someone must know what the name of these bulbs are?
Homer
Northeast Indiana
Posted: 03/03/12 02:55pm Link  |  Print  |  Notify Moderator
Bayonet based bulbs.
Dick A
Spokane
Posted: 03/03/12 02:57pm Link  |  Print  |  Notify Moderator
The bulb you have is a Xenon 18 watt, 12 volt, wedge base T-5 or T-8 base lamp.
2009 Tiffin 43QBP Allegro Bus
RoadMaster Sterling Tow Bar
US Gear UTB
Ford Explorer Sport Toad
FinLee
108 Mile Ranch, BC
Posted: 03/03/12 03:28pm Link  |  Print  |  Notify Moderator
thanks, so it can be reffered to as t-5 or t-8 or doe it have to be one of the two?
bukhrn
Lanexa, Va
Posted: 03/03/12 06:59pm Link  |  Print  |  Notify Moderator
Is this what you have?
http://www.google.com/url?sa=t&rct=j&q=&........-OgPpr8K8pWA&sig2=wenBkS6kSWmn-fjH4j4DdA
2007 Forester 2941DS
2005 KIA Spectra
FinLee
108 Mile Ranch, BC
Posted: 03/03/12 07:37pm Link  |  Print  |  Notify Moderator
I think thats it, it looks like it anyhow. So A T-5 it must be! Thanks.
RoyB
King George, VA
Posted: 03/04/12 07:27am Link  |  Print  |  Notify Moderator
Finlee - where are you wanting to use the replacment LEDs. Alot of the RV trailers use either the 921 or 1141 bulbs. There is a ton of info on here about changing over to LEDs. It has alot of info available to you for which LEDs to use.
My suggestion is only order ONE LED replacemnt and try it out before jumping in there and spending $150 to find out they dont work like you want. There are a couple of rules to follow - one is it must be in the 250 and higher LUMEN rating to be as bright as your 921 bulb and also you probably want to use WARM WHITE to about the same color of light that the 921 bulb produces. If you purchase the board replacement type that have built-in regulators on them you may experience RFI issues that will knock out your HDTV and NOAH Wx Radio receptions especially when you are using the OTA outside antennas.
Read up on the many posted article here for LEDs before buying something.
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
