Joneseyhome
Renton, WA
2008 Carriage Lite with electric grey and black valves. When I push the open for 2 seconds the led doesn't light up. I know a bunch of water and waste went thru the hose BUT my control says the tank is FULL. I'm in deep s__t!!! Please help!!!!!
Jonesey
ksg5000
Oregon
The gauges that indicate whether the tank is full are notoriously inaccurate - a small bit of TP or debris stuck to the sensor will make it register. Common problem - no big deal.
Kevin
Artemus Gordon
Redding California
Answer: Very carefully!
2012 Montana 3750 Hickory Edition, 2013 Ford F450 Crew Cab 4x4 Platinum options
2012 3750 Montana
Generator Box
Eycom
32043
ksg5000 makes a good case. The black tank is the worst. Try refilling the Blk tank with just water and dumping again. Usually from one to three flushes will clear the Blk tank sensor. That gets old after awhile. With time, you'll learn how often you need to dump and the Blk sensor won't matter. Just make sure the tank is 3/4 to full before dumping. If you have a Sani-Flush or similiar, use it often. When the water runs clear, you're good.
RVn Full-time
HappyKayakers
Black River Falls WI
2 suggestions. First, get a clear elbow for the end of your sewer pipe. That way you can verify that you're flushing clean on the black tank. Second, never be satisfied with just dumping the tank without one or more additional fill/flush. Just dumping without checking and extra flushing will eventually leave some TP stuck on the blade valve. That will keep the valve from closing completely in the future so your liquids will drain constantly and your solids will form an ever growing and hardening pyramid.
Also, quit worrying about your sensors. When you flush the toilet and it burps, you're almost full.
Joe and Dakota, the wacko cat
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2006 Heartland Bighorn 3600RL, MorRyde suspension, TrailAir pinbox
http://happykayakers.com/blogger/
Finally Fulltiming
Summer: NYS Finger Lakes; Winter: Someplace warm
Just shut off your water supply & fully open the "flush" pedal or handle on your toilet. On a sunny day you should be able to simply look down into the tank & observe the level of the contents. At night, use a flashlight.
But plug your nose just in case.
Shipper
Lower Alabama
Finally Fulltiming wrote: Just shut off your water supply & fully open the "flush" pedal or handle on your toilet. On a sunny day you should be able to simply look down into the tank & observe the level of the contents. At night, use a flashlight.
If you want to be exact, just carry a yardstick and use it as a dipstick. Just remember to wipe it off well before storing.
This message was spell checked before posting!
Don't you wish everyone did?
"I'm not insensitive, It's probably that I just don't care!"
mlts22
Austin, Texas
The yardstick also doubles as a way to scrape off part of the poo pyramid underneath. Just wipe it off, and store it in a garbage bag, well marked, and well away from everything else.
LarryJM
NoVa
Shipper wrote: Finally Fulltiming wrote: Just shut off your water supply & fully open the "flush" pedal or handle on your toilet. On a sunny day you should be able to simply look down into the tank & observe the level of the contents. At night, use a flashlight.
All I can think of is YUCK, that is disgusting IMO.
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
Shipper
Lower Alabama
LarryJM wrote: Shipper wrote: Finally Fulltiming wrote: Just shut off your water supply & fully open the "flush" pedal or handle on your toilet. On a sunny day you should be able to simply look down into the tank & observe the level of the contents. At night, use a flashlight.
 All I can think of is YUCK, that is disgusting IMO.Larry
You could always throw the yardstick away instead of wiping it off and storing it!
