RV.Net Open Roads Forum: Class C Motorhomes: power inverter
 > power inverter
polish al
trenton nj
Posted: 03/03/12 04:29pm Link  |  Print  |  Notify Moderator
does a 4000 watt plug in inverter have enough power to make a satellite receiver work? i dont want to use the generator to power it. i also need to know if there is a double 12 vt. outlet that you can plug into a single 12 vt. outlet? i am on the beach alot with my 4x4 motorhome and i have a doulbe battery in the house that i use to power everything.i would like to run the tv on 12 vt. and plug the inverter in to power the box. i will only use the inverter for the box. ...thanks
Crazy Ray
Monroe,La
Posted: 03/03/12 04:37pm Link  |  Print  |  Notify Moderator
4000 watt plug in inverter is a OVERKILL. I think you have a 400Watt? Look at it again.
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
polish al
trenton nj
Posted: 03/03/12 05:01pm Link  |  Print  |  Notify Moderator
my mistake.. a 400 watt inverter!!!!!!!!!
enblethen
Moses Lake, WA
Posted: 03/03/12 04:55pm Link  |  Print  |  Notify Moderator
You need to re-read the label of the inverter.
My satelite receiver draws max of 25 watts.
A 400 watt would be overkill!
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
skipnchar
Topeka or somewhere else
Posted: 03/03/12 04:39pm Link  |  Print  |  Notify Moderator
It would probably run about 20 of them
2oldman
Winchester WA
Posted: 03/03/12 04:43pm Link  |  Print  |  Notify Moderator
You can check the wattage rating of any appliance by the label on it.
NewsW
US
Posted: 03/03/12 05:29pm Link  |  Print  |  Notify Moderator
Maximum power from a 12V outlet is normally about 15amp.
Estimate the inverter efficiency at 50%.
That is the most you can easily draw.
D.E.Bishop
Eagle Rock, CA
Posted: 03/03/12 05:43pm Link  |  Print  |  Notify Moderator
I just checked my 19" Dynex flat screen TV and it pulls 35 Watts. I curently run a 13" CRT TV, DVD player or RCA Converter Box and a RF modulator. Can't give you the wattage on the TV, converter and modulator because they are in the rig in storage and the TV is cabinet mounted and I can't see the plate.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
ScottG
Bothell Wa.
Posted: 03/04/12 09:17am Link  |  Print  |  Notify Moderator
If it's a MSW inverter then it's going to be very efficient - well above 95%. PSW inverters are lower but still much better than 50%.
Scott, Grace and Wesly
H0NDA eu2000i
sonicsix
Jerry n' Cynthia
Posted: 03/05/12 06:05pm Link  |  Print  |  Notify Moderator
We run a 22" TV, satellite receiver and 2 laptops on a 300 watt PSW inverter.
 > power inverter
