buc1980
houston tx
What the method the people use to install the engineering wood in the FW.Do I need to level the floor if is not level?Any suggestion you can give me I will appreciate.Thank you.
2011 Ford F350 DRW,2005 Kountry Star 35ft,Breaksmart controller(not install I use Ford controler ),Equa-Flex.6 points LIPPERD Level-up.
Home Skillet
Pearland Texas
The latest Motor Home magazine has a nice write up on installing hard wood floors.
Since the RV frame flexes quite a bit, floating floors would be the best.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,SmarTire,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Bruce3404
Eugene, OR
I have a floating floor (Allure) and have had no problems with it; I've probably put 4000 miles on my rig since installing the floor.
SWD
Land of Living Skies
Have Pergo floating floor. Installed about 5 years ago and have done over 10,000 miles with no issues. Its as good as new.
camperpaul
Wherever I park my travel trailer
Home Skillet wrote: The latest Motor Home magazine has a nice write up on installing hard wood floors.
Not just frame flexing but also temperature and humidity changes...
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
1982 6.2L Diesel Suburban 1500
buc1980
houston tx
What the people think laminate or engineering wood.
Jetta03
Alberta Canada
Floating is probably the best for ease of install, repair, etc. but be careful to select something that is water tight. Something like the allure tiles stick to each other but not the floor surface.
It's no fun having to lift a replacement floor if you spill or leak water under it.
