RV.Net Open Roads Forum: Toy Haulers: blowing tires
Search only in Toy Haulers
 > blowing tires
sunnybrooktoyhauler
new jersey
Posted: 03/03/12 05:49pm Link  |  Print  |  Notify Moderator
Hi all! I have a 2008 sunnybrook 39surv toy hauler. my problem is I keep blowing the rear tires on the third axle. Any sugestions. Thanks
eHoefler
ozark mountains
Posted: 03/03/12 06:00pm Link  |  Print  |  Notify Moderator
Do have torsion/rubber ride suspension?? Is the trailer perfectly level when hooked up, loaded, and ready to travel?? Most likely you are nose high. You are overloading the rear axle running nose high. Even an inch out of level will cause one or the other axle to be overloaded.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
Old-Biscuit
Across the USA
Posted: 03/03/12 06:12pm Link  |  Print  |  Notify Moderator
What tires......brand/size?
What pressure are you running in tires?
What are the axle weights.......would be best to weigh each axle to see what they are carrying..not just the total load.
I too would suspect overloading on rear axle/tires.......coupled with under inflated for load, scrubbing tires (rear set gets a lot of twisting/scrubbing when doing tight turns).
Wills250psd
walnutcove NC
Posted: 03/03/12 06:28pm Link  |  Print  |  Notify Moderator
the rear axle usually gets more abuse, when turning its in a serious bind. Are you nose high? will
Chuck&Gail
In the Colorado Mountains
Posted: 03/03/12 07:13pm Link  |  Print  |  Notify Moderator
If the tires are made in China, that is more likely also. Why not weigh each axle? As said, likely you are running nose high putting excess load on rear tires.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
lincster
Mesa Az
Posted: 03/03/12 08:25pm Link  |  Print  |  Notify Moderator
Go buy some 16" LT tires. Michelin XPS Rib specifically. You won't have any more issues even if you do tow nose high.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Strabo
Host "AGW-RALLY'S"
Posted: 03/03/12 10:31pm Link  |  Print  |  Notify Moderator
We run Firestone Transforce H/T load range E tires on our 5ver, xlnt tire.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 660 SS106-ITP-K&N-JetKit-T4-CDI-CVT-Grant-Holder LED LightBar-HID Conversion Kit-UV Whip
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
SoCalDesertRider
SanDiego, CA, USA
Posted: 03/03/12 10:45pm Link  |  Print  |  Notify Moderator
I would suspect the trailer is nose-high.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
old guy
Oregon (pronounced Or e gun)
Posted: 03/03/12 11:11pm Link  |  Print  |  Notify Moderator
happened to me too, I just went down to the tire store and told my friend I was tired of having blow outs, so he put some real heavy duty over sized tires on the TT and haven't had any blow outs since. those tires in the rear of your TT are taking all the beating or abuse and need to be upgraded.
phillyg
Front Royal, VA
Posted: 03/04/12 07:27am Link  |  Print  |  Notify Moderator
Suspect you're nose high, too. Purchase an inexpensive infrared thermometer, make sure the tires are at the right psi in the am, and check tire temps after a long haul. I'll bet your rears will be running hotter than the front two sets.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
 > blowing tires
