RV.Net Open Roads Forum: Class A Motorhomes: No hot water pressure
 > No hot water pressure
justlou
Northern, Illinois
Posted: 03/04/12 07:02am Link  |  Print  |  Notify Moderator
The check valve is not the one with flip lever on it. That is the pressure/temperature relief valve. The check valve is on the rear of the water heater on the output water line. The small plastic inner piece is prone to failure and will restrict or block the hot water flow from the tank.
justlou
2006 Monaco Diplomat
2004 Saturn Vue Toad
Dale.Traveling
Newport News, VA
Posted: 03/04/12 07:11am Link  |  Print  |  Notify Moderator
daverich wrote:
Can I put lime away in the fresh water tank and drive down the road a little bit to mix it well and then run it through the pipes?
That's a scary idea. The stuff is only a few steps below Drain-O or Easy-Off. No telling what if might do to the various fittings, seals and such. Plus it's not the cat's meow dissolving heavy mineral deposits (rock in other words).
How is the water flow if the heater is bypasses? Half split the system. Flow bad pipe restriction, good flow tank blockage. One other item not mentioned was to check for an air bubble in the tank. Too much air will not allow the water to reach the discharge at the top of the tank. Give the safety valve a burp. You want some air but too much of anything isn't always a good thing.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
daverich
Swan Lake National Wildlife Refuge, Sumner, MO
Posted: 03/04/12 07:19am Link  |  Print  |  Notify Moderator
Check valve sounds like something I am not up to. Sounds like a visit to repair.
I did try shutting off the by-pass and that made no difference.
For now, I will forget the lime-away until after a repair person looks at it.
Thanks guys or gals which ever.
daverich
Posted: 03/04/12 07:20am Link  |  Print  |  Notify Moderator
I did the burp of the safety valve last night. Did not appear to have any air in it.
LennyH
Pennsylvania
Posted: 03/04/12 07:30am Link  |  Print  |  Notify Moderator
One last thing, did you check the drain in in your water compartment, it would be the Red line from the Hot Water Heater to make sure it was not open?
Lenny H
pkunk
Questa, NM
Posted: 03/04/12 09:12am Link  |  Print  |  Notify Moderator
I had a problem with one faucet on the MH once and found a screen at the bottom (under the sink) where the HW feed goes into the faucet
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
pkunk
Questa, NM
Posted: 03/04/12 07:40pm Link  |  Print  |  Notify Moderator
Do check to see if you have a screen in the line where it connects to the bottom of the faucet. Mine had one and it was clogged with junk from the water heater.
daverich
Posted: 03/04/12 07:51pm Link  |  Print  |  Notify Moderator
I will do that tomorrow pkunk. To many Crown and Cokes tonight.
Thanks!
vtbigdog
VT, GA
Posted: 03/04/12 05:12pm Link  |  Print  |  Notify Moderator
Does the cold water flow ok? If so and if the throwing of the bypass valve does not alter the water pressure on the hot side, you either have a problem somewhere between your outside hose and the lines to the water heater and bypass like a valve open, or the problem may be with your faucets.
When the hot water heater filled, did it fill quickly? Could you hear the water running?
Richard
2003 Safari Trek 3011
8.1 Workhorse/Allison
daverich
Posted: 03/04/12 05:30pm Link  |  Print  |  Notify Moderator
No valves open or closed that should not be. Hot water heater filled just like always.
We are at another park tonight which has water pressure of 50 to max of 55. I am getting more out of the kitchen sink and a little more out of both the bathroom faucet and tub faucet.
I called a friend of mine and explained the situation to me. He said he had seen something similar and it was a hot water line that the manufacturer had bent around a corner instead of using a corner joint. He said with time apparently the HOT water had softened the plastic pipe just enough that is slowly starting closing itself. What think you?
As it stands now, I am going to wait until we get back to Northwest Missouri in two or three weeks and have a RV shop I know take a look at it. In the mean time I will use campground showers or sponge baths.
