RV.Net Open Roads Forum: Convert a 15 pass Ford E van to a B & TT tower - Thoughts?
 > Convert a 15 pass Ford E van to a B & TT tower - Thoughts?
kurtswen
NJ
Posted: 03/03/12 08:50pm Link  |  Print  |  Notify Moderator
I am considering buying a 2006-09 Ford E-350 15 passenger wagon and doing an interior fix up to make it in to a B camper and a TT tow vehicle. The idea is to use it as a B camper when doing trips to relatives, hotels, rental houses, summer tent trips. Also use this vehicle sometimes as a tow vehicle for a 26' to 28' travel trailer or boat(6-7K pounds). Interior change ups would be to remove all stock seating and install new driver, pass and two rear passenger seats. Maybe leave the third row bench feet for those few times its needed. Back would be bunks or bed and/or counter, maybe micro and/or small refer.
We are a family of 4, 2 big and 2 small!
Thoughts/ideas/suggestions/places to go to learn more/project pics?
2007 Winnebago Sightseer 35J
Workhorse
Towing 1995 Jeep Wrangler
NewsW
US
Posted: 03/03/12 09:11pm Link  |  Print  |  Notify Moderator
Been there done that.
Specify the conditions of operations, what you want to achieve, how much you want to spend, etc.
Key is seats in back must be safe... also insulation key ... ventilation.. plus and minus of starting from cargo vs passenger.. etc.
Handbasket
Asheville, NC
Posted: 03/04/12 05:37am Link  |  Print  |  Notify Moderator
kurtswen wrote:
Ford or Chevy, non issue!
I'd suggest you have whoever's going to be sitting in the front passenger's seat sit in one of each before saying that so emphatically...
Jim, "Mo' coffee!"
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory') www.tigervehicles.com
booster
Minnesota
Posted: 03/03/12 09:15pm Link  |  Print  |  Notify Moderator
I think there is a good chance you would go over weight with that much trailer, plus the Ford has a long rear overhang, so the tongue weight and trailer could make it a handful. A Chevy is a bit better as the wheelbase on the extended vans is longer than the Fords, if you don't mind a Chevy.
kurtswen
NJ
Posted: 03/03/12 09:34pm Link  |  Print  |  Notify Moderator
Ford or Chevy, non issue! Reliable and buildablilty is the issue for a starting platform. The B side would be mostly warmer weather use, 40+ deg. Goal is effectively a tow vehicle that can bring 4 - 6 people comfortably to boat or TT use area.
I was thinking non cargo because of the finished interior walls already. Good or bad? Are the finished van interior walls "insulted" or really just sound proofed?
Fantastic Fan would be a up on the roof. Even thought about an Espar heater from aux tank for a heater. Porta potti.
I suspect I will be close on the weights for bigger trailers and so we are looking for a smaller TT with features we want. I believe I can deal with the overhang with the spreader bars.
Golden_HVAC
Fulltime, CA, USA
Posted: 03/03/12 10:59pm Link  |  Print  |  Notify Moderator
Hi,
I might have suggested converting a cargo van, without the windows, but you can get front and rear A/C and heat in the window vans, not the cargo van.
The disadvantage to the extended 15 passenger van is a really long rear overhang, the distance from the center of the rear axle to the trailer ball. If over 6' long, then the trailer hitch weight starts to really overload the rear tires, and you don't have duallys back there.
The 350 series 8 lug nut 12 passenger van has a slightly shorter rear overhang (about 18" shorter van overall, and thus 18" less between the hitch ball and rear axle). If the trailer hitch weight is insignificant, say 800 pounds, it will not matter. But a heavier travel trailer, then it might make a difference.
Somehow I think that after taking a 26' travel trailer camping, then taking the boat to the lake with a tent, it will be the last tent trip that you take the little kids on (ie without a shower, bathroom, refrigerator, stove and oven). So might as well plan on taking the travel trailer on all the camping trips once you have it.
A fantastic fan in the roof is always a good idea to get ventilation while parked. You will need to have a location for a second battery in the conversion, and plan on bringing a ice box when tent camping or hotels. With the trailer, all the cold stuff can stay in there.
The Ford V10 has plenty of power for pulling a trailer, or the boat, even out of the lake. I know some people that full timed in a 34' Airstream trailer pulled by a short length E-350 for several years.
Fred.
NewsW
US
Posted: 03/04/12 05:47am Link  |  Print  |  Notify Moderator
The maximum towing weight of the E-350 long wheelbase with the 6.0 diesel is 10,000 lbs.
With the V10, it is 9,400lbs.
There is no issue with the length of the van as long as normal loading / weight distribution issues are addressed.
In fact, I just had a look, and the extended van overhang is about the same, if not shorter than the overhang on a Suburban --- one of the most common tow vehicles.
Plenty of good Trailers for 4 people for under 7,000 lbs.
I derate factory towing capacity by about 30% to get to my "comfort zone".
* This post was edited 03/04/12 06:46am by NewsW *
retraite
Wanderin' about
Posted: 03/04/12 05:48am Link  |  Print  |  Notify Moderator
Jim, "Mo' coffee!"
Amen, brother. And, I'd ask them to sit there for awhile. Then just watch their face. That'll answer the question.
That's one of two details that sent us scurrying to the Chevrolet platform. The other was the rear axle overhang, given that we regularly tow.
Cheers.
ennajean
Wisconsin
Posted: 03/04/12 06:50am Link  |  Print  |  Notify Moderator
As the passenger in a ford B.....I have no problem with the leg room.
Anne and Dick
DABEE a 2006 Ford Sportsmobile Penthouse top.
States we've camped in.
NewsW
US
Posted: 03/04/12 09:07am Link  |  Print  |  Notify Moderator
Removing / modding the snap in "bin" on the doghouse greatly improves ability to move from seat to back.
Another solution is to tweak the seat mountings a bit...
But that gets into rules, regs, and crashworthiness.
