joe0508
charlotte
Are their an easy to read kill a watt that i can use that is color coded.One that will have a needle that will move to green if good and red if bad.Instead of having to read numbers.
joe money
tahiti16
Camarillo, CA
Kill a watt measures amps used I don't think that is what you are asking about. More like a voltmeter and they do have a green good yellow and red bad areas.
Ray, Cheryl, Cory & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
Kiwi_too
Western, WA
Kill A Watt measures volts, amps and watts.
I would not want one with a needle as they are more inaccurate. They are analog. The Kill A Watt is digital. I use a digital because it is more precise. I would recommend that you adjust to the digital display for that reason. When I walk by mine, I always note the voltage. If below 108 or above 129 I will take appropriate action. I use those thresholds because 105 & 132 is the danger points and I do not want to take action after electricity hits the danger points.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
randco
Somewhere in time
Kiwi_too wrote: Kill A Watt measures volts, amps and watts.
I think that you would need to sit and watch the meter constantly. A severe voltage drop or spike can occur in an instant. You won't have to to "take appropriate action".
If you want to control under voltage and want surge protection use a Powermaster Autoformer voltage controller. Powermaster
In my opinion the Powermaster Autoformer is better built than the Hughes Autoformer.
ryanallie1
Magalia, Calif
Hi All.
I have a pretty good back ground in Electrail. And this is what we use.
"LINK"
This is a so called "Poor Mans Meter". We have used ours for quite a few years with no issues what so ever. Very easy to check from a distance, at a glance and tell what color reange it is in.
Its cheap and pretty darn accurite. You can take the cover off and adjust the Needle. What we have done, is check the incomming power with a Multi-Meter, then adjust the Needel to read the same, or as close to it as you can, since its an Anolog Meter.
There are more accurite Meters, "Digitals" that cosat a lot more.
We are not "obsessed" with the power as some are. It doesn't have to be 100% accurite to still be ok to use. This will give you a pretty darn good idea of the incomming power where ever you are staying.
We do check our Power Supply, before we ever plug our RV's into it.
We also do use a pretty good "Surge Protector" also. If all you want is the general information of what the power is, then this is more than good enought to use.
If you want dead on, exact power, then spend more and buy a dood Digital.
In the 45 years as RV'ers, we have never lost anything to Power Surges or Spikes or Lightning or anything else you can think of, in our RV's
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
wa_desert_rat
Central Washington State
The Kill A Watt is a remarkable gadget; all the more so for its price. I used one to determine how much power our new 19" HDTV draws so I could decide what type of inverter I needed. Turns out that both the HDTV and the BluRay draw use than 30 watts of power so a cheap $29 plug-into-the-cigarette-lighter inverter does the trick just fine.
I used it to adjust our genset so the frequency was exactly at 60Hz (a KAW will give you the frequency of your alternating current power source).
No RV is complete without one!
Craig
wny_pat
Western NYS
Think we need to pull out of the OP what he thinks a "kill a watt" is and what he wants to use it for. Otherwise, this thread could go on forever.
jauguston
Bellingham, WA
A FWIW on adjusting cycles with a Kill-A-Watt meter. If your generator is a typical built in RV generator and not a inverter type the governor on the engine is not very precise in holding rpm. For that reason the cycles are directly related to rpm and will vary with load. If the generator is operating normally the cycles(rpm) should be set at 62 cycles not 60 cycles no load. This is a allowable variation. Again if the generator is operating properly with no problems as you add load the cycles (rpm) will drop until at full rated output the cycles should be about 58 cycles. Inverter type generators like our Onan QD 7500 or the portable Honda EU series and many other inverter portables control cycles electronically and will always be right on 60 cycles
Jim
edited 03/04/12 12:27pm by jauguston *
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
Kiwi_too
Western, WA
randco wrote: Kiwi_too wrote: Kill A Watt measures volts, amps and watts.
Agreed. Kill A Watt is not for constant monitoring and does nothing for spikes or brown outs. I do have a Hughes Autoformer for routine, unmanned, power regulation. This still has it's limits. I use a portable Surge Guard to test power at the pole, before connecting. After connecting, with autoformer in line, we double check the power on the Kill A Watt before turning on 120v systems. Then as we move about I simply glance at the Kill A Watt to confirm power is not dropping. If the power at start up or during periodic glances drops below 110 we look more often. Our Kill A Watt is by the mid entry door so it is in the path of most things, in or out of the coach.
wny_pat wrote: Think we need to pull out of the OP what he thinks a "kill a watt" is and what he wants to use it for. Otherwise, this thread could go on forever.
Good question/response.
Wherever I happen to park
You want green and red.. Well the problem is the Kill-a-watt has no idea what is "Good" or "Bad" it is designed to measure volts, amps, the relationship between current and voltage (It is an angle, it gives you the cosine) Volt-amps, Watts (not the same thing) voltage and frequency.
But there what is "Good" or "Bad" depends on what you plug into it. So ther eis now way it can be pre-set to "Turn red" you got to read the numbers, AND know how to interpret the numbers.
I have taken electronics in college, I have passed the Amateur Radio Extra Class test (Which deals with all the things that meter measures) and **I** Can not tell you what is "Bad" save for voltage < 108 or more than 128 is not good.
