Thinking about putting my battery bank on some type of sliding tray so I can slide them in and out to check water,condition and so on of the batteries. Anyone else buy or fabricate a slider for their batteries-how about some pictures.
I know it is a good idea because most of the people in the GMC group have done this. I don't know if this tray will fit your 5er at all, but it is a start. See it here.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog going to see some dry places that have Geocaches in a coach made the year we married.
My only concern would be not to interfere with the ability of the installed batteries inside the trailer compartments to properly vent battery fumes to the outside vent and to allow for over-flow battery drainage to the ground under trailer.
A pull-out tray would be great for me to use if those fuming and over-flo conditions were also met. It would be a tricky install for my fifth wheel inside compartment battery install with-out cutting an new access door in the side of the trailer. My batteries are installed in individual sealed and vented battery cases below the opening of my front large access door. I have to remove four screws per battery box to pull a lid to check my battery water level. Thanks goodness for my "smart mode" charging converter as evertime I check the water level is always ok... All of that would have to be changed to support a pull-out tray for me.
My Posts are IMHO based on my experiences - PM me Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
