RV.Net Open Roads Forum: Tow Vehicles: What is Cummins around 2013 Model Year...
Search only in Tow Vehicles
 > What is Cummins around 2013 Model Year...
tkcrawford
Edmonton, Alberta
Posted: 03/04/12 08:16am Link  |  Print  |  Notify Moderator
NewsW wrote:
What is going to be interesting is how long do the DPF last in the light duty setup.
In the medium duty engine, the DPF only last 200,000 to 400,000 miles.
Another side note...
ISB in medium duty takes 4 gallons of oil.
Unlike the sissy version sold for Dodge.
As far as I am aware, the 6.7 installed in Dodge pickups is already classified as a medium duty engine. The sissy versions of Duramax and Powerstroke are classified as light duty.
2004 Dodge Laramie 3500 Dually, CTD 305/555, Quad Cab, 4x4, NV5600
2008 Eagle Cap 995
ib516
Up here!
Posted: 03/04/12 08:29am Link  |  Print  |  Notify Moderator
Isn't the sissy version in the Ram also in the sissy F650 and F750? And several pieces of agricultural, power generation, and mining equipment? And don't the Powerstroke and Duramax also use DPFs?
Troll on....
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
jwduke
Ice Cream Capital of the World (Le Mars), Ia.
Posted: 03/04/12 08:41am Link  |  Print  |  Notify Moderator
You don't see the sissy versions of the Powerstroke or the Duramax in any other application, outside of what they are already in.
'04 Dodge 2500 QC 4x4 w/CTD
'03 Hitchhiker II 31RLBG
NewsW
US
Posted: 03/04/12 09:10am Link  |  Print  |  Notify Moderator
rickatic
Don't tell them I am in petroleum!
Or the stuff I am posting on is right up my homework alley.
Not often one get to do homework and post at same time.
Nearly as hard as walking and chewing gum at same time.
tkcrawford
Edmonton, Alberta
Posted: 03/04/12 09:17am Link  |  Print  |  Notify Moderator
ricatic wrote:
MM49 wrote:
I'm Rick James wrote:
749 posts in 27 days. That has to be some sort of record. Do you have any hobbies?
Yes, It would be very intresting to know which company he works for?
MM49
Does it count as a job when the person in question is also a PHD currently working at a highly respected research university toward yet another advanced degree?
Just sayin...
Regards
Letters after your name are all well and good but don't necessarily prove anything in the real world. I've known PHD's that are hard pressed to figure out how to change a light bulb.
I'm Rick James
Reno, NV, USA
Posted: 03/04/12 09:20am Link  |  Print  |  Notify Moderator
MM49
Just sayin...
Regards
If trolling on RV.net will qualify at a "highly respected research university toward an advanced degree" then this place is chock full of geniuses. I'm going to head out to the picture frame store as I've got some doctoral diplomas to hang on the wall.
I'm Rick James
Reno, NV, USA
Posted: 03/04/12 09:22am Link  |  Print  |  Notify Moderator
Troll on....
That's Dr. Troll to you!
Turtle n Peeps
California
Posted: 03/04/12 09:36am Link  |  Print  |  Notify Moderator
NewsW wrote:
rickatic
ROTFLMAO, with your 10,000 RPM turbo remark I knew it was not in internal combustion engineering.
outside the fire"
gmcsmoke
Butler
Posted: 03/04/12 09:45am Link  |  Print  |  Notify Moderator
MM49
Just sayin...
Regards
Yet, somehow, he can't communicate a coherent sentence, post a link or spell you're name correctly.
Yeah...a real Einstein.
Say the title of this thread out loud one time?
The path to internet posting is hard you walk.
Turtle n Peeps
California
Posted: 03/04/12 10:30am Link  |  Print  |  Notify Moderator
MM49
Just sayin...
Regards
Remember; many, many, many very respected PHD's with advanced degree's working for Bosch caused all of the pump problems that caused all of your financial loss with your truck.
Harland and Woloff had many, many, many PHD design engineers work on a ship they built around 1900.
Thomas Andrews was the man...........aaaaa.......errrrrrr..........until he was killed on the ship he designed when it hit a chunk of frozen H2O in the midle of the Atlantic.
So to answer your question. No, I'm not impressed.
I do find it ironic that metallurgy caused the sinking of a beautiful ship "might" cause the sinking of a new beautiful engine.
All because of some PHD "thinking" they knew what they were talking about.......but didn't. Ironic indeed.
