marlin.3374
jacksonville,fla
i have a 2010 toyota tundra with a v-6, the trailer weigh's in at 4,600 lbs, my question is does any body know what the guess on fuel milage. thanks
bugs53
Jacksonville, Fl
My daughter pulls theirs with a Nissan Titan and has no trouble at all.
Bugs53
bugs53
08 Tiffen Allegro, Wrangler Shahara.2dr std, Us Gear Breaking
Mango 3speed cruisers
Cookie. Springer Spaniel
popeyemth
owensboro ky
its not the wieght so much as the wind resistance that affects milage. the shape of the camper nose and the speed you pull it all affect wind resistance. the shape you cant alter but your speed you can. SLOW DOWN= better milage.
"wine is a constant proof that God loves us, and loves to see us happy" ben franklin
pulsar
Lewisville, NC
Moved from Forum Technical Support.
eric james
Sioux Falls, SD
I'll guess 7-9 mpg.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
cekkk
Colorado
Ten seems to be a popular number.
'11 Eagle 320RLDS
Equalizer WDH
'02 Ford F350 dually, unchipped 7.3 PSD, PacBrake,
6.0 cooler, Ford AIS and Isspro trans. gauge
Replaced old AirLift airbags
bikendan
Napa, Cal.
bugs53 wrote: My daughter pulls theirs with a Nissan Titan and has no trouble at all.
Bugs53
a Titan has a 5.6L v-8 engine, not a v-6!
i actually didn't know that the newer Tundras could come with a v-6.
i looked the specs for the 4.0 v-6 Double Cab and it said that the tow max is only 4500lbs. with the factory tow package.
so, you're over your tow max unless you have some more info. and worse if it doesn't have the tow package.
to the OP, you don't state whether that's the "dry" weight or actual factory sticker weight.
Dan- Firefighter , Shawn- Musician/Entrepreneur , Zoe- Faithful Golden Retriever , 2007 Chevrolet Avalanche LS, 2007 Rockwood Roo 23SS w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
bugs53
Jacksonville, Fl
Sorry I missed the origonal post.
Bugs
jerem0621
Sequatchie, TN
What I find ironic is that the little 4.0 V6 in the Tundra has more HP and only slightly less torque than my 97 5.4. The Tundra has a 4.10 rear end on the V6 and my truck has 3:55 rear end.
Yet my tow rating is almost 4k lbs more.
Makes no sense to me.
Thanks
Jerem
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
Road Ruler
Canada
jerem0621 wrote: What I find ironic is that the little 4.0 V6 in the Tundra has more HP and only slightly less torque than my 97 5.4. The Tundra has a 4.10 rear end on the V6 and my truck has 3:55 rear end.
Makes no sense to me. Thanks Jerem
Tow ratings make no sense to many of us!
Airstreams.... the best towing trailers on the planet!
