Katt1
Many Mansions RV Park
I am upgrading from existing 1992 Prowler/Regal(5th wheel)thermostat to a Honeywell model RTH111 /RTH221. I have labeled existing wiring,they are as follows.
Existing wiring
R = RH / RC jumpered
B = ? Instructions say do not hook this wire up.
Y = Y
W = W
GH = ? Fan wire I believe (heat)
GI = ? Fan wire I believe (AC)
New thermostat hook up
Y
G
RH
RC
W
How to arrange old wiring to new thermostat?
help please it's getting hot in here.
Thanks ahead of time for everyones input
Katt
Warm and loving it.
Grandkids and loving them.
Life and loving it.
rhochnadel
Colorado
Normally wires are hooked up as followws: RH/RC for power source, W for heat, Y for cool, and G for fan. If you do not have any instructions with your new thermostat, start with these connectctions and test. Wish I could help you further.
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"
rtaylor0830
davidsonville md
gl is low fan gh is high fan
donn0128
Pronounced Ore-gun
Katt1 wrote: I am upgrading from existing 1992 Prowler/Regal(5th wheel)thermostat to a Honeywell model RTH111 /RTH221. I have labeled existing wiring,they are as follows.
Existing wiring
Y = Y
W = W
GH = ? Fan wire I believe (heat) Fan high speed (AC)
GI = ? Fan wire I believe (AC) Fan low speed (AC)
Y
G
RH
RC
W
Katt
You need to buy a mini SPST switch also. Do a search for wiring schematics and instructions for wiring the T-stat using the function above and print them off. It is a simple job if you follow the instructions.
Go here for instructions.
http://www.rverscorner.com/hunterstat.htm
edited 03/04/12 11:53am by donn0128 *
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Chris Bryant
DeLand, Florida, USA
A lot depends on whether you are working with a Coleman or DuoTherm unit. They work differently.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
alageezer
seale, al
When we installed our Honeywell thermo, we checked the difference in the fan speeds from high to low. Seeing as how there was very little difference, we just hooked the high speed up, and didn't bother with the low speed or installing a seperate switch.
No complaints so far.
2011 Bounder Classic
Wiscampsin
Wisconsin USA
Chris Bryant wrote: A lot depends on whether you are working with a Coleman or DuoTherm unit. They work differently.
I'm curious, what's the difference?
2013 Palomino Sabre 34 REQS-6
http://s1340.beta.photobucket.com/user/W........6?&_suid=1357224714962013706578115184365
LAdams
Northern Illinois
Wiscampsin wrote: I'm curious, what's the difference?
IIRC, Coleman switches hot leads for activation, Dometic switches ground leads for activation... Most Atwood Furnaces function by switching ground leads...
Chris will correct me if I'm wrong...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
Chris Bryant
Les is right, plus Dometic (DuoTherm) has to have both high and low fan grounded for high fan operation.
Wiscampsin
Wisconsin USA
Thanks Les and Chris. Les, it was your link that I used to install my previous thermostats. We ordered a new Forest River 5er. Delivery is 6 weeks out. When I looked at one at the dealer I noticed it said 'Dometic' on the Tstat. It's digital, not programmable, but I want to install a Hunter programmable one. If it's alot different than the Coleman directions any other tips on how I would wire it?
Thanks
edited 03/05/12 10:01am by Wiscampsin *
