RV.Net Open Roads Forum: Fifth-Wheels: Need an opinion from the "weight police"
 > Need an opinion from the "weight police"
Page of 5
CLHEJ
Greenville, SC
Posted: 03/04/12 08:45am Link  |  Print  |  Notify Moderator
Hey all. It looks like I am getting one step closer to a complete new rig. I am negotiating on a 2012 Chevy 2500HD Crew Cab 4wd with a standard box. After researching the tow ratings, it looks like my max tow rating is 15,800 pounds and I would assume that is for gooseneck/fifth wheel towing.
I'm currently looking at 5ers with a dry weight of 9000-11000 pounds.
What do you all think?
Thanks in advance!
Craig
Craig & Lillian
2008 Dodge Ram 2500 MEGA Cab Cummins "BlueTec", HyperTech Max Energy, Fitch Fuel Catalyst, Prodigy brake control, Reese Dual Cam
2003 Sportsman 3004SS (in search of a bigger,better TT)
mguay
Northern NH
Posted: 03/04/12 08:57am Link  |  Print  |  Notify Moderator
Pin weight is the biggest problem. In most rivers the storage is in front of the axles adding pin weight. Those numbers are comparable to mine dry. My dry pin weight was 1900 according to the manufacturer. Wet on the scales it was 2400. I started with a 2500 but made the jump to a DRW. Not because the 25 had problems towing....but because it would beat me to death on long trips. We are not retired and when we go far we have a schedule to keep. With the 25 I could make it about 500 miles before having to stop. With the DRW I can roll between 700 and 800 at 70 mph and barely know it's there. If your plan is to go on weekends and only an hour os so from home than a 25 is fine. The DW feels so much more safe in the DRW that she even drives from time to time.
Real Trucks wear Training Wheels!
fj12ryder
Platte City, MO
Posted: 03/04/12 09:06am Link  |  Print  |  Notify Moderator
Don't pay much attention to "Dry Weight". What you should look at is GVWR since that is going to be closer to your actual weight when you get ready to travel. I think that a 5er with a "Dry Weight" of 9-10,000 lbs is actually going to weigh closer to 11-12,000 lbs with a corresponding increase in pin weight to around 2300 lbs.
To me that is at the upper limit of your 3/4 ton truck. JMO of course.
Howard and Peggy
"Don't Panic"
ScottG
Bothell Wa.
Posted: 03/04/12 09:07am Link  |  Print  |  Notify Moderator
Why not just pay the small ($600~1K) price and get a SRW 1 ton? Or even better yet A Dually? If your buying new anyway why start with something marginal?
Scott, Grace and Wesly
H0NDA eu2000i
MTPockets1
Posted: 03/04/12 09:10am Link  |  Print  |  Notify Moderator
Tow rating is one measure, and you will be fine there, but cargo/payload is more important. Don't know about Chevy, but new F250 Ford 3/4 ton payloads run from 3000 lb to 4000 lb depending on GVWR package and options. The more options on the truck, the lower the payload rating. A 5vr with a dry weight of 11,000 lbs will probably have a GVWR of 14,000 - 14,500 .... You need to look close at the pin weight and maximum payload potential of truck and 5vr.
My 5vr delivered dry weight is 11,760... Pin weight is 2300 lbs. When I load the basement and closet I add another 500 lbs ..... The 5vr Hitch is a couple hundred lbs, and two adults in the cab, Full tank of fuel and other loaded items in the 5vr, some fresh water, holding tanks (should be empty when towing) so in our case we're at a payload of 3500 lbs. That's why we went with 1 ton truck and we're still closer than I would like, but under rated capacity.
2012 3055RL Big Horn - Dexter 7000 lb axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
downtheroad
Pacific Northwest
Posted: 03/04/12 09:17am Link  |  Print  |  Notify Moderator
Thanks in advance!
Craig
One ton...diesel
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
NC Hauler
Asheville NC
Posted: 03/04/12 09:21am Link  |  Print  |  Notify Moderator
Thanks in advance!
Craig
as stated above, dry weight is a joke...you need to go with the 5er's GVWR..Can you tell us what the GVWR's of the 5er's are?
The newer 3/4 ton trucks have upped their GVWR's and their GCWR's so depending on the GVWR of the 5er, one may be doable and one may not be...
As also stated, no more difference in price than there is, depending on the GVW of the 5er, you may want to opt for more GVWR and GCWR by paying a little more for a 1 ton SRW truck....but again, knowing the actual GVW of the 5er's would help the most.
Can't really go by "max tow rating" "IF" the pinweight of the 5er exceeds the trucks GVWR or it's RAWR.....your on the right track, just need to tighten up on your math a little more.
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
gmcsmoke
Butler
Posted: 03/04/12 09:33am Link  |  Print  |  Notify Moderator
^this. Payload on a 3500SRW CC SB is 3931 with the LTZ package. There's a 1500 payload difference between the two so with everything being equal a 2500 would only have a 2400 payload.
not much towing capacity whatsoever.
Mile High
Denver, CO
Posted: 03/04/12 09:44am Link  |  Print  |  Notify Moderator
Move on to the 3500. In as much as you are now looking for a bigger trailer, you will be looking for a bigger truck if you sell yourself short now.
My 11,300 lb dry weight 5er is now almost 14,500 lbs. and pin weight can get as high as 3,000 lbs if I'm not careful.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
donn0128
Pronounced Ore-gun
And in the real world that number can shrink to 1700-1800 pounds in a matter of seconds.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Page of 5
