RV.Net Open Roads Forum: Tow Vehicles: which tow vehicle?
Search only in Tow Vehicles
 > which tow vehicle?
mike2894
United States
Posted: 03/04/12 09:03am Link  |  Print  |  Notify Moderator
I need a tow vehicle for a 24ft 5th wheel with gvwr of 11,635, dry weight 6860. I'd like to get a f150 ecoboost, but I'm not sure that enought to tow my rv. all advise appreciated. Mike
fj12ryder
Platte City, MO
Posted: 03/04/12 09:11am Link  |  Print  |  Notify Moderator
IMO at GVWR of 11,635 you're looking at the upper limit of 3/4 ton truck. Most of the time the GVWR is close to your actual travel weight.
Howard and Peggy
"Don't Panic"
MTPockets1
USA - Usually West
Posted: 03/04/12 09:15am Link  |  Print  |  Notify Moderator
F150 is not the truck for that much pin weight and cargo.
2012 3055RL Big Horn - Dexter upgraded axles - G rated LT Tires
MorRyde, Genset, Dual Panes, 2 A/C, Yeti Package
2013 F350 DRW 4x4 Crew King Ranch
NC Hauler
Pence Springs WV
Posted: 03/04/12 09:16am Link  |  Print  |  Notify Moderator
Don't go by dry weight...no one travels "dry"....you have clothes, pot's, pans, dishes, bed clothes, outdoor chairs, full propane tanks and so on...it adds up after a while...even if you only loaded up to 10,000# believe you would be pushing the limits of the F150's GVWR with the 5er's pin weight that could reach up to 2,000# or more. There are lighter 5er's that the F150 can tow, but believe I'd lean towards a 3/4 ton with that weight....
"IF" you only loaded to around 8,000# or so, might be ok, but it's a guessing game until the actual weights are known
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
AZ T&T
Mesa, AZ
Posted: 03/04/12 09:18am Link  |  Print  |  Notify Moderator
That trailer is a little heavier than mine and I had to add air bags to my 3/4 ton.
AZ T&T
2012 Jayco Eagle Super Lite 29.5RKS
2011 Chevy 2500 HD 4x4 Duramax
B&W Companion Hitch - Firestone Ride-Rite Air Bags
Honda EU2000i Generator
Lowsuv
Oregon
Posted: 03/04/12 09:25am Link  |  Print  |  Notify Moderator
Diesel HD 2500.
Everything lasts longer especially under hard use.
Every 1500 or F150 is a compromise as a tow rig.
Fancy styling, leather seats, and a GPS monitor do not increase tow capacity.
However, those same features will keep you from doing the right thing.
sirdrakejr
Las Vegas, Nevada
Posted: 03/04/12 09:28am Link  |  Print  |  Notify Moderator
Moved from 5th wheels to tow vehicles.
Frank
APT
SE Michigan
Posted: 03/04/12 11:46am Link  |  Print  |  Notify Moderator
I would get a 1-ton SRW and be done. 7k dry, 8k wet/loaded for a trip. 1500-2000 pounds of payload before you add a 200 pounds hitch and people in the cab. 3/4 ton gasser or 1-ton crew cab. EB is fantastic, but it's a stretch on payload for even a Supercab 8200 pounds GVWR HD F-150.
2017 Subaru Outback 3.6R
ib516
Way up north eh
Posted: 03/04/12 05:14pm Link  |  Print  |  Notify Moderator
Seems heavy for such a short 5er. Arctic Fox?
In any case, I'd suggest a 2500 minimum, maybe a 3500 SRW for an 11,000# GVWR 5er.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
All above are sold
Current: 07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
SeaRayder
Alabama
Posted: 03/04/12 07:28pm Link  |  Print  |  Notify Moderator
I towed my 7180lb dry fiver today with my EcoBoost F-150HD, and it did great! It is a fine TV for a lightweight fiver. It tows WAYYYYY better than my old F350 dually ever did. Now if you are towing ALOT or are a full timer a 3/4 or 1 ton would be better but for the occasional trip the F150HD is a great choice.
-SeaRayder
Current RV: 2009 Keystone Springdale 280FWIKSSR Fifth Wheel
Current TV: 2012 Ford F150 Heavy Duty Crew Cab EcoBoost Lariat 4x4
