RV.Net Open Roads Forum: Fifth-Wheels: Slide Carpeting
 > Slide Carpeting
troyb
Alberta, Canada
Posted: 03/04/12 10:41am Link  |  Print  |  Notify Moderator
The carpeting on our slide is starting to lift alont the front edge. It looks like it is stapled down from the factory but some are missing or have come out. Would it be better to staple this down again or use some flooring adheasive? Anyone had to deal with this before? Not too big of an issue but just kind of annoying. Thanks
2008 Chev 1 Ton Dually Crewcab Duramax, Banks Speedbrake and IQ
2008 KZ Escalade 37REB
ronfisherman
SE Michigan
Posted: 03/04/12 01:34pm Link  |  Print  |  Notify Moderator
A air operated stapler is what I used to fasten down carpeting in my RV.
Kodiak Chassis Class C Forum
whporwil
Minnesota
Posted: 03/04/12 03:40pm Link  |  Print  |  Notify Moderator
We had this problem. It was caused by closing the slide and part of the seal along the bottom of our slide ripped off and came in with it, so check your seal. I used a hand stapler to refasten the carpet and it hasn't been a problem. I also replaced the seal.
troyb
Alberta, Canada
Posted: 03/04/12 06:41pm Link  |  Print  |  Notify Moderator
Thanks. I do have an air stapler and will use this.
sirdrakejr
Las Vegas, Nevada
Posted: 03/04/12 09:18pm Link  |  Print  |  Notify Moderator
Why not use both. Use the adhesive and then staple it to hold until the adhesive cures.
Frank
Charlie D.
E. Texas-Orange
Posted: 03/05/12 05:09pm Link  |  Print  |  Notify Moderator
I agree with Frank. Our carpeting is held down with double sided tape and it has worked pretty well
Enjoying Your Freedom?
Thank A Veteran
Native Texan
 > Slide Carpeting
