RV.Net Open Roads Forum: Class A Motorhomes: Deep Cycle Battery Replacement
 > Deep Cycle Battery Replacement
Edouard
Hudson QC. or Lake Worth, Fl
Posted: 03/04/12 10:43am Link  |  Print  |  Notify Moderator
We've been experiencing lack of 12 volt ability to raise/lower our window shade, and extending/retracting the auto awning, waiting several minutes and several attempts to operate them.
The 2 x 6 volt interstate deep cycle's are about 5 years old, their specific gravity are about 1275-1300 in the green zone, and showing 12.6 average when taking a reading, but fail to provide ample voltage when needed as mentioned above. No apparent issue to operate the Norcold 12 volt function, water pump on occasion, etc.
I am of the opinion that the Xantrex inverter/converter/charger should be providing 12 volt when we are connected to shore power, but it appears that not to be the case, anyone have imput on this?
In doing a search here it appears people have good results with BJ's, Walmart and Costco deep cycle golf cart batt's.
Where should I look to pick up a decent deal on a couple of deep cycle batteries? Thanks.
Eugene & Stella
08 Dolphin DL35C, WH-24, Allison 6 Spd.Tranny.
2013 Kia Soul 4U.Automatic, Rental Tow Dolly for now.
FMCA 318247
rvrepairnut
bc
Posted: 03/04/12 10:58am Link  |  Print  |  Notify Moderator
If I were you I would be checking out why your converter is not charging your batterys while plugged in before just going and buying batterys
enblethen
Moses Lake, WA
Posted: 03/04/12 11:12am Link  |  Print  |  Notify Moderator
Before doing any replacement, locate where you are loosing power from the charger. You should be getting normally over 13 volts to the batteries. It could be just dirty connnections on the batteries.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
DUNEBUGGYDOUG
SHELBY FOREST TN.
Posted: 03/04/12 11:02am Link  |  Print  |  Notify Moderator
you poor thing
CA Traveler
The Western States
Posted: 03/04/12 11:07am Link  |  Print  |  Notify Moderator
New batteries won't help much until the charger is fixed. Buy a $5 DVM and post the battery voltage. Then clean and maintain the batteries and have them load tested.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
GPWayne
Lake Stevens. WA
Posted: 03/04/12 11:22pm Link  |  Print  |  Notify Moderator
Check out the Xantrex inverter/converter/charger "control panel". Read the manual for how to set it up. If you don't have a manual you can download it.
They even have a video showing how it works and how to set it up.
Edouard
Posted: 03/05/12 07:16am Link  |  Print  |  Notify Moderator
Batteries & connections are clean, acid level is correct and maintained, voltage when charger is on is 13.+ volts, when off it's 12.6 approx. It's only when putting a load on there is insufficient voltage apparently. I do have a DVM, that's how I posted voltage in my OP.
I will be picking up a Load Tester today, will than do a Load test and proceed from there. Thanks everyone.
lwasouth
Posted: 03/05/12 07:33am Link  |  Print  |  Notify Moderator
Why are some of our members so nasty. If you can't say something constructive or at least nice, you should keep your "Your poor thing" to yourself
RSchleder
iowa city, ia
Posted: 03/05/12 07:44am Link  |  Print  |  Notify Moderator
I second this comment.
enblethen
Moses Lake, WA
Posted: 03/05/12 07:48am Link  |  Print  |  Notify Moderator
I purchased my 6 volters from Costco for about $80 each.
What happens when running on shore power? Does it work properly? If yes, there is a bad connection in the system. Could be around fuses or circuit breakers controlling the defective items.
