Bordercollie
Garden Grove, CA, USA
2004 Fleetwood Tioga 26Q, has front TV cabinet with typical Winegard amplified "Batwing" TV antenna.
When I connected our new Vizio 22" LCD TV to the bedroom antenna connector, I received fewer digital major network TV channels than when I connect to the front TV antenna connector which is located closer to the Winegard amplified antenna assembly. Before I start tearing into the RV and checking tightness of connections,etc., Have others noticed this? Does the added length of the coax cable running to the rear bedroom reduce the signal strength enough to cause this situation?
enblethen
Moses Lake, WA
Start by checking the TVs setup. Make sure it is in the correct over the air function.
I would change out the coax between wall outlet and TV set making sure it is not the problem. Do the same in the front.
Connect the TV straight from the antenna power supply to tv. That will help determine where the problem is. If signal is better, inspect the connectors inside the wall connections.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
MNtundraRet
Bloomington, MN
Pulling the plate slightly from the wall will allow you to check and tighten the coaxial connection. The signal is weaker in the bedroom since there are more connections involved. Your's may also go through a switch-box which adds 3 more connections to deteriorate the signal (input, switch, output).
Substituting a separate cable as mentioned by Bud is a good suggestion.
A second RF signal amplifier placed in line between cable-out at amplifier-box and television input can greatly improve signals and stations found. I use a Radio Shack model purchased two years ago.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
j-d
Sunny Florida USA
If you need to add your own connectors to the coax cable, get a Coax Stripper Tool. The signal is carried on the thin coating on the wire core. Not the core itself. Compromise the coating and the signal deteriorates. This per Chris Bryant RV tech extraordiaire.
God Bless, jd
2003 Jayco Escapade 31A on 2002 Ford E450 V10 4R100
j-d
Sunny Florida USA
That said, a Winegard "Wing Man" add-on will improve your DTV reception.
hotbyte
Barnesville GA
Did you also have the amplifier turned on when connected to the bedroom connector? It is probably fed from the amp so turning it on also boosts signal to it.
Our Web Albums Temporary Web Albums
2006 Yellowstone SE, 1998 Dodge Durango SLT 5.2L and 2011 Tidewater 1900 Bay Max
NewsW
US
Amplifier --- function check first.
Then... use this neato tool:
http://www.tvfool.com/?option=com_wrapper&Itemid=29
From this, you can quickly get a sense of what the art of the possible is given your precise location, height, and also where to point your antenna.
Bordercollie
Yup, I had the new Vizio connected to the front antenna connector with button pressed and green amp light on, ran scan again got many more channels than when connected to rear antenna connector. When connected to rear TV connector, the additional station numbers, appeared on TV screeen, but no picture or sound. I'll check inside wall connector plate in bedroom, hopefully just unscrewed.
enblethen
Moses Lake, WA
Sounds like a bad connector or loose connection.
rrupert
NW PA
Coax cable and connectors eat signal strength and with higher frequencies being transmitted on DTV that makes it worse. You need to get high quality RG6 cable and connectors and keep the length as short as possible with the least amount of connectors.
edited 03/04/12 06:18pm by rrupert *
Rich and Joyce
2010 HiLo 2310H
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
