RV.Net Open Roads Forum: Class C Motorhomes: Slide stopped working Gulfstream BTouring Cruiser
 > Slide stopped working Gulfstream BTouring Cruiser
Jsanner
Havelock, North Carolina
Posted: 03/04/12 12:37pm Link  |  Print  |  Notify Moderator
I had just gotten home and was opening up the slides and the bedroom slide hung up a;little - I brought it back in then out then back in and it is stuck - any help out there on how to get it working again - the switch makes a contact noise - I think I got it off the track somehow.
Thanks in advance
2008 5291 BT Cruiser
fortytwo
Livingston, TX
Posted: 03/07/12 07:31pm Link  |  Print  |  Notify Moderator
Gulfstream put the smallest motor they could find in the BT. First check to see if you picked up a lot of dust/dirt on the rails. Clean if necessary. I would use a lot of liquid silicon spray on the tracks as the next step. I sold mine 4 years ago and don't remember if there is a way to manually extend. You can get a couple of folks to push to retract.
Wes
"A beach house isn't just real estate. It's a state of mind." Pole Sitter in Douglas Adams MOSTLY HARMLESS
Jsanner
Posted: 03/08/12 05:10am Link  |  Print  |  Notify Moderator
GS did send me some slide info - I can easily fix now - thanks for all of the advice!!!!
