RV.Net Open Roads Forum: Travel Trailers: Tongue jack
 > Tongue jack
NH68GTO
NH
Posted: 03/04/12 03:38pm Link  |  Print  |  Notify Moderator
Getting new white hawk 27'. Looking at electric tongue jack. Dealer is quoting 300. Looking on amazon to save some cash.
What size do I need to lift this camper ?
Dominick
2012 Jayco White Hawk 27DSRL
alageezer
seale, al
Posted: 03/04/12 03:42pm Link  |  Print  |  Notify Moderator
Good tongue jacks of about 3500 lbs can be had from e-bay for about $100 from several sources. Three bolts and a fused hot wire to the battery takes about 15 minutes to swap.
2011 Bounder Classic
Turbo Diesel Dude
Ocala,Fl
Posted: 03/04/12 03:47pm Link  |  Print  |  Notify Moderator
As alageezer said. 3500lbs will lift anything you could pull JMHO, Most anywhere is cheaper than a dealer.
charles weidman
WyoTraveler
Wyoming
Posted: 03/04/12 03:50pm Link  |  Print  |  Notify Moderator
You could have a tongue weight of 1200 so I would want something that would handle quite a bit more than that.
in5r
Indiana
Posted: 03/04/12 04:00pm Link  |  Print  |  Notify Moderator
Keep in mind you need to make sure you get the correct diameter jack for this trailer. If I am not mistaked there are two sizes.
2012 Ford F-250 6.2 CC SB
2015 Jayco Eagle HT 28.5RSTS
bobfears
louisville
Posted: 03/04/12 04:23pm Link  |  Print  |  Notify Moderator
Tell the dealer NO DEAL if the jack isn't included. You will be suprised what will happen if you start to walk.
301TBS
Ontario, Canada
Posted: 03/04/12 04:49pm Link  |  Print  |  Notify Moderator
The hole it mounts in, also make sure it has a lower support plate.
2012 Crossroads Z1 271B
2009 F150 Scab 4x4, 4.6, 3v. 6spd. 3.73/9.75
Reese dual cam
NH68GTO
NH
Posted: 03/04/12 04:43pm Link  |  Print  |  Notify Moderator
Diameter of what ??? Need more info.
coolbreeze01
Redding, Ca
Posted: 03/04/12 05:06pm Link  |  Print  |  Notify Moderator
I'd buy a 3500# jack, but no need to panic. Research is a good thing and usually free. Enjoy your new rig.
2008 Ram 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2014 Sandsport 26FBSL
rozell
Nigara area
Posted: 03/04/12 05:10pm Link  |  Print  |  Notify Moderator
sounds like a very heavy tongue weight
 > Tongue jack
