RV.Net Open Roads Forum: Travel Trailers: WDh
jassms98
inland empire
Posted: 03/04/12 06:32pm Link  |  Print  |  Notify Moderator
Hello All We just bought our First TT. We are so excited. I have decided to go with Equalizer WDH. What size 1000/10000 or 1200/12000. TT is GVWR 7660 and hitch weight is 660. The tt does have a front storage. TV is 2011 F150 SC 4x4 max tow pkg. joe
2011 F150 4x4 6.2 Platinum
2012 ViewFinder 28BHSS
Equal i zer WDH
old guy
Oregon (pronounced Or e gun)
Posted: 03/04/12 06:37pm Link  |  Print  |  Notify Moderator
well in my way of thinking I would go with the 1200. if in a few years you needs change and you get a larger TT then you will not have to pay again for a larger capacity WDH.
clearnetedm
Alberta
Posted: 03/04/12 06:46pm Link  |  Print  |  Notify Moderator
Congrats on your new trailer. As for the wdh I would try and match as close to your weight and in your case the 1000 would be a better fit. Too much wd can cause other issues and too much of a wdh can cause issues like porpoising and other rough ride issues. In some case can cause issues to the tounge of the trailer but I don't think that would be a risk.
Just my thoughts.
2008 Ford Expy EL
2012 Rockwood 2601S
skipnchar
Topeka or somewhere else
Posted: 03/04/12 06:53pm Link  |  Print  |  Notify Moderator
Size your hitch based on the trailers GVWR without being LESS than that amount. Assume 15% or GVWR as loded tongue weight.
Good luck / Skip
eric james
Sioux Falls, SD
Posted: 03/04/12 07:35pm Link  |  Print  |  Notify Moderator
7660 x 13% = 995 lb tongue weight at GVWR.
Get the 1000 lb unit. You'll never tow at 7600 lbs.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
