RV.Net Open Roads Forum: Fifth-Wheels: 7 way in truck bed?
 > 7 way in truck bed?
02super250
Wisconsin
Posted: 03/04/12 06:33pm Link  |  Print  |  Notify Moderator
I have the hitch in and want to put my plug in the box again on this new truck and don't remember what size hole to make.Anyone know?
Please and thank you
2011 F350 Lariat 4x4 CC DRW Powerstroke 3:73,LineX,Duraflaps on all four corners,BAK Flip F1.
2011 Keystone Alpine 3640RL
nremtp143
Georgia
Posted: 03/04/12 06:35pm Link  |  Print  |  Notify Moderator
The Bargman 7 ways are either a 2" or 2 1/4" hole... I believe it is the later...
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
forwardho
DFW -- Texas
Posted: 03/04/12 07:38pm Link  |  Print  |  Notify Moderator
Drill a hole into a piece of wood before you do your truck. This way you can check to see if it fits.
2004.5 Dodge Ram 3500 Dually - AKA Blue Thunder
Quad Cab SLT 5.9L Cummins HO Turbo Diesel
48RE Trans w/Mag-Hytec DD Pan @ Temp Gauge
18K Hitch
50 Gallon Auxillary Fuel Tank
Viper Security System
2003 35' Cardinal Fifth Wheel--AKA Motel 9
forwardho
Luke Porter
Not on the road :(
Posted: 03/04/12 07:44pm Link  |  Print  |  Notify Moderator
It's 2".
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
wittmeba
Virginia
Posted: 03/04/12 08:26pm Link  |  Print  |  Notify Moderator
Post for plug in bed:
You can use the plug at the bumper with an extension cord. No need to drill large holes in the truck bed. Ford truck bed is a double wall and the cord runs inside the walls. You may need to undo one end connector to pass thru the hole in the truck bed wall and the bracket. Cable is color-coded to match the marked connectors. Easy to reassemble.
1 male connector
1 female connector
1 8' 7 conductor cable
1 mounting plate
About $30.00 total
You can buy an extension for about $25.00 terminated with the right connector on each end. You may need to remove one end for lacing the wire.
Extension cable:
http://www.amazon.com/CAMPER-TRAILER-CABLE-CONNECTORS-LENGTH/dp/B003R2SMW6
Bracket here:
http://www.kaffenbarger.com/index.php?productID=192
If you tow any kind of utility trailer with brakes, the connector is still at the bumper for use.
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
bigdon68
Churchville, Maryland
Posted: 03/06/12 06:14am Link  |  Print  |  Notify Moderator
02Super250
Check MY PICTURES below. I ran my plug from under the truck and up through the driver side rear taillight and into the bed.
Take a look. It worked out real well.
Be safe. Bigdon68
2008 F350 CC 2WD LB 6.4 Lariat Auto SRW, Retrax, AirSafe Hitch, CB, Train Horns, On-Board air, RideRites, Aux Tank
2007 Ameri-Camp SummitRidge Reserve,40ft, Onan, MorRyde IS, Disc Brakes,17.5 Alcoa Wheels, Michelins, dual AC, Bigfoot Levelers
MY PICTURES
02super250
Wisconsin
Posted: 03/06/12 05:11pm Link  |  Print  |  Notify Moderator
I have the path on how I want to run it just making sure what size hole saw to get from work.
sure2rain
Sunbury, PA
Posted: 03/06/12 05:26pm Link  |  Print  |  Notify Moderator
As Luke noted 2" is the size. But Forwardho has a good idea of pre-drilling in a scrap of wood.
TV: 05 Chevy 2500 8.1L
5er: 2010 Open Range 385RLS
Hensley Arrow and P3
