After reading here about leaving the shore cord plugged in at home....I dug deeper and checked the ratings on my converter and see that the float "trickle charge" is like 13.2 volts...... well that will just keep charging the batteries more than they need.... the salesman said he leaves his plugged in all winter...yeah he has a real expensive 5vr... mine is a lot less priced. So I guess don't leave it plugged in all the time? Does that mean I have to check the battery level or voltage and plug in occasionally?Or leave it plugged in?
Help...I'm a newbie when it comes to a house battery and shore power....been really dry camping without for years.
As stated, 13.2 volts is NOT more than your battery needs. Check the recommendations from your battery manufacturers web site. You'll find figures from 13.2 to 13.6 rather common.
If you don't keep your rig plugged in then you should disconnect your batteries otherwise the various parasitic draws on the battery will deplete the battery overtime. If your rig has a modern smart converter you can keep your rig plugged in and check the battery level ever few months - if it's an old fashioned single stage converter then you should check the battery level every few weeks.
Perfect...I will then leave it plugged in. Very glad to have the help and know how from you all here...thanks.
Can't wait to use it camping soon.....just need to get rid of this cold weather and snow!
