No giving us much to work from. A side profile picture of the truck trailer hitched up would be worth a thousand dart board guesses on the root problem.
Towing set up -IE level trailer frame allows the trailer suspension to use the full range of travel. Very important -as porpoising and chucking are greatly accented by a nose high trailer. Nose high trailer compresses rear axle and unloads front axle. Compressed rear axle directly affects ride quality of the trailer. Your GM dealer probably won't coralate this issue either as they will be focused on issues within your truck.
IMO all trailers should have some type of dampening system between the tires and frame. Either shock absorbers or cushioned equalizers. Without these items all roadway related shocks are transmitted to the truck via the coupling (hitch)system.
mapguy wrote: No giving us much to work from. A side profile picture of the truck trailer hitched up would be worth a thousand dart board guesses on the root problem.
I agree. After installing an Equa-Flex suspension on my 5ver along with a Mor/Ryde pin box my chucking has been eliminated. I think this is why there have been some frame problems over the years.IMO
Anytime I began experiencing chucking, I would put a new layer of grease or Teflon Lube on the Hitch plate. It was kind of counterintuitive because you would expect the grease to make everything more slippery. It has the opposite effect because of fluid dynamics, it creates a suction due to the viscosity of the grease and the pin weight. It kind of acts as a shock asborber to slow down the motion and eliminate the chucking. Wow I don''t know where all that science stuff came from.... I guess I did pay attention in physics.
ok here is some of the info you guys are asking for . my Coleman 5er has a UVW of 7,694 and a GVWR OF 10,560. my 2010chevy silver ado has a trailer wt capacity of 12,156 and a max tongue wt of 3,039 and a GVW of 9,200. it has 410 gears with a 6.0 vortex engine ,with bilsteen shocks on the truck and air bags. the actual scale weights have not yet been returned to me from the dealership yet i will post them when i get them . as for pictures as soon i can get my daughter to show me how how to get them from my phone to the computer i will also make them available . i hope i haven't confused things any worse than they are and appreciate your input and advice thanks much.
paul1
PAUL1A wrote: ok here is some of the info you guys are asking for . my Coleman 5er has a UVW of 7,694 and a GVWR OF 10,560. my 2010chevy silver ado has a trailer wt capacity of 12,156 and a max tongue wt of 3,039 and a GVW of 9,200. it has 410 gears with a 6.0 vortex engine ,with bilsteen shocks on the truck and air bags. the actual scale weights have not yet been returned to me from the dealership yet i will post them when i get them . as for pictures as soon i can get my daughter to show me how how to get them from my phone to the computer i will also make them available . i hope i haven't confused things any worse than they are and appreciate your input and advice thanks much.
paul1
Paul, what we are interested in, is how much weight is sitting on your hitch in the bed of the truck. This is called "pin weight". You need to weigh your truck and trailer to get just that pin weight value. There is a sticky at the top of this forum for weights, and it should explain how to do it, so I won't repeat it here.
Here is why the pin weight value is important. Imagine your truck and trailer hitched up and going down the road. Now imagine that there is zero weight on the truck hitch, and the trailer is just balanced there. I'm sure you can imagine the trailer acting like a teeter-totter as it rolls down the road, because it is equally balanced in front of and behind the axles. To stop the teeter-totter you would want more weight on the hitch end of the trailer. The above is an exaggeration to make a point. Your chucking feeling is from the weight of the trailer bouncing up and down on the hitch, just like the teeter-totter, because it is not heavy enough in the front.
Well, that is one possible reason, and I think the most likely reason. But we won't know until you figure out how much weight is on the pin. We want it to be at least 20% of the total trailer weight.
The gooseneck pull proves it not basic problem with the truck. Is your hitch solid? That seems to common link since you pulled a different 5th wheel and had similiar issues? What kind of hitch do you have?
its a pro series 1600 hitch . ile post the pin weight as soon as i get them, but i can tell you this ,when i hitch the 5er the truck bed really drops with weight. and i use the air bags to get it level. paul1
ok fellas my weight numbers are here i am not sure how to interpret them but this is what they say , on 9/11 the first weight is 8170 the second is 980 and the third is 15410 i hope this helps i cant say for sure but i think the 15410 is truck and rv together ,i think that the8170 is the rv and think the 980 is pin weight .maybe you guys can figure it out.
paul1
