RV.Net Open Roads Forum: adding water heater on?off switch inside rv
 > adding water heater on?off switch inside rv
skipnchar
Topeka or somewhere else
Posted: 03/05/12 09:24am Link  |  Print  |  Notify Moderator
If you install one inside I'd be sure you also have a locking pin on it so you don't accidentally turn it on when it should be off. It'll burn up your heater pretty fast. I figure I'm already outside when setting up camp so I turn it on and off at that time.
xxjanaleexx
NE Pennsylvania
Posted: 03/05/12 12:28pm Link  |  Print  |  Notify Moderator
Just switch the circuit breaker off that is marked for the water heater!!!
Driver,"Jan"..Navigator,"John"..Social Director,"Mittzi" our cat
Retired,relaxed,and enjoying life....with our...
2003 Wildwood 26FLS
1999 Chevy Express 1500 Conversion Van
"Life is a journey--enjoy the ride !"
301TBS
Ontario, Canada
Posted: 03/05/12 02:03pm Link  |  Print  |  Notify Moderator
You are too smart for this forum, that would have saved me a lot of work.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
Chuck&Gail
In the Colorado Mountains
Posted: 03/05/12 03:06pm Link  |  Print  |  Notify Moderator
Note using circuit breakers as "switches" causes them to fail very early IMHO. They are NOT switches.
I just cut the supply wire and added an illuminated switch in series. Worked great. Outside switch just left always on. Done that on two TT's so far. Current TT had switch already wired, thanks Keystone.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
anoldman
Middle Tennessee
Posted: 03/08/12 05:56pm Link  |  Print  |  Notify Moderator
I tried doing that on my camper. Even though nothing else was on the breaker label it turned out the power converter was. Wound up with a dead battery too. I bought an Atwood wall switch that has both gas and electric switches in it. Wired in Radio Shack micro LED's in the switch plate so it's easy to see when either is left on. Then I added a relay into the 120v line going to the water heater. Yeah, it was a lot of trouble to do all of that, but it looks nice and works great.
mikestock
Vestavia Hills, AL, USA
Posted: 03/08/12 09:53pm Link  |  Print  |  Notify Moderator
That is what I have always done. The water heater has been on an independent breaker in each of my last three RV's. Just leave the outside switch on all the time. This doesn't affect the operation in the gas mode if I need to go that way.
If it causes the breaker to eventually fail, I'll replace it. They aren't expensive.
2005 F250 Crew Cab LWB Power Stroke, 2007 Montana 3500RL Fifth Wheel,Honda EU3000IS, Twin Honda EU2000i's, S&W security system
cpaulsen
California
Posted: 03/09/12 02:10am Link  |  Print  |  Notify Moderator
Same thing I did.....works just great!!
cpaulsen
