RV.Net Open Roads Forum: Class A Motorhomes: 89 southwind
 > 89 southwind
toreador06
madera
Posted: 03/05/12 05:04am Link  |  Print  |  Notify Moderator
were to buy parts for my 89 southwind im in madera ca
pulsar
Lewisville, NC
Posted: 03/05/12 05:07am Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support.
harold1946
Surprise Arizona
Posted: 03/05/12 05:26am Link  |  Print  |  Notify Moderator
Let us know what parts you are referring to. Coach parts or chassis parts?
Make and model of coach?
Make, model and year of chassis?
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
toreador06
madera
Posted: 03/05/12 07:34am Link  |  Print  |  Notify Moderator
i need the cut off suitch for my batteries theres two one batteries and the other one for water pump etc.etc 1989 southwind p30 chassis 454 chevy by the way switches are rt above entry door
harold1946
Surprise Arizona
Posted: 03/05/12 07:54am Link  |  Print  |  Notify Moderator
Most auto parts stores will have them. They are not unique to motorhomes.
enblethen
Moses Lake, WA
Look closelt at the switches. They should be double pole double thro momemtary center off. Many RV store stock them.
JR products
What is wrong with yours or the system?
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
toreador06
madera
Posted: 03/05/12 08:08am Link  |  Print  |  Notify Moderator
cant get my water pump to work or to check my batteries, propane ,gray water,black water,no power that all. no problem to start my rv . even when charge batteries all day and night still no power
psa0298
Alberta
Posted: 03/05/12 08:22am Link  |  Print  |  Notify Moderator
It probably is not the switches. You may want to check ALL fuses and circuit breakers first. I have a 1990 Southwind, I tripped a circut breaker for the 12V house system. The circut breaker is under the hood, it is a small cirular push in style. It may be in the 12V electrical panel on the left side...Sorry I can't remember exactly where, this happened to me last summer and my MH is in storage right now. Start checking the easy things first like fuses, circut breakers and connections.
harold1946
Surprise Arizona
Posted: 03/05/12 08:24am Link  |  Print  |  Notify Moderator
I would check the breakers at the converter/inverter first. Coach power is generaly not supplied by the chassis battery so it would not effect starting.
Chech the battery connections for tightness and clean terminals, a bad ground could also be the cause.
enblethen
Moses Lake, WA
Posted: 03/05/12 08:48am Link  |  Print  |  Notify Moderator
There is a fuse in most that supplies power to switch.
I would check the power to the relay first. There should be battery power on one side and when not connected to shorepower it should have battery power on the other side if the relay is in connected mode.
No power would indicate that the cable to the battery or the ground cable is bad.
If you have power, there should be a main fuse in the DC section of the power center. The DC powr center is normally located adjacent to the AC breakers behind a small metal "deadfront".
 > 89 southwind
