RV.Net Open Roads Forum: Fifth-Wheels: 50amp Electric Requirements?
 > 50amp Electric Requirements?
CA Traveler
The Western States
Posted: 03/05/12 05:00pm Link  |  Print  |  Notify Moderator
BCSJBaylor wrote:
Just bought the thing and haven't had it out yet. But let's assume a vacation to Florida in June-July. You would recommend a second A/C?
Yes and I'd install 2 15K sized ones.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
jaycocamprs
Ringgold Georgia
Posted: 03/05/12 05:46pm Link  |  Print  |  Notify Moderator
BCSJBaylor wrote:
Damn...gotta add another thousand bucks to my wish list!
So when I see these devices that you plug your 50-amp cable into and it splits between 30-amp and 20-amp plugs, that would be a different type of 50-amp than what would be "normal"?
Yes that would be 50 amps total, not 100 amps total.Get one that has 2 30amp plugs. Gives you 30 amps on each leg, 60 amps total. You can run both AC's this way. 20 amp plugs are GFCI if they are up to current code, and they will trip.
The "dogbone" style adapters feed both leg with 1 30 amp feed and you are limited to that 30 amps. If running this way I run the water heater and fridge on propane. And really watch what we run at one time.
What I see different in this 50 amp trailer over the last 30 amp trailer is, this has 2'nd AC, washer dryer plug, and plug for fireplace. All are 20 amp and on their own breakers.
2005 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Snowman9000
IL
Posted: 03/06/12 06:32am Link  |  Print  |  Notify Moderator
Where do you plug two 30A plugs in at the pedestal?
2004 Chevy Duramax 2500HD 2WD Crew Cab. B&W Patriot hitch.
2004 Crossroads Cruiser 28RL 5er.
2005 R-Vision Trail Lite B+ 213 6.0 Chevy 3500
christopherglenn
a little over an hour from Yosemite
Posted: 03/05/12 05:58pm Link  |  Print  |  Notify Moderator
30 amps give you two large loads at a time.
AC (each), Microwave, electric water heater, hair drier, etc
You may get 1 large and 2 medium loads, Coffee pot, toaster, curling iron, electric fridge, etc at a time.
When you first plug in the converter is going to be at max output topping off the batteries, then less of a load to offset the lights, fridge electronics, co detector, fans, etc.
On a 30 amp circut I would have to alternate the water heater, microwave, and AC to keep from popping the post braker. My biggest problem was the teenagers hair drier sneaking up on me and tripping the braker.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Mile High
Denver, CO
Posted: 03/05/12 06:23pm Link  |  Print  |  Notify Moderator
I didn't read what you originally said correctly - Jaycocampers is right. Those devices use the 30A and 20A to give you 50A - SOMETIMES. As I understand, some of the campgrounds that were modified feed the 30A and the 20A from the same 30A breaker upstream of the pedestal, so you really never get more than 30A. Some campgrounds ban those devices and I don't remember why.
2006 Ford F350 4X4 SB CC SRW Powerstroke 6.0
2013 Redwood 36RL - full paint - disk brakes
"Comparison is the thief of joy! - Theodore Roosevelt"
CA Traveler
The Western States
Posted: 03/05/12 06:42pm Link  |  Print  |  Notify Moderator
BCSJBaylor wrote:
The converter I was talking about allowed you to plug in your 50-amp in one end and then out the other end came 2 cords...one with a 30-amp plug and another with a 20-amp plug. I guess the theory there is that if the electrical box has both 20-amp and 30-amp plugs, they'd be on different circuits so you can use both circuits to get your 50-amps???
This is also known as a cheater cord. You get 30A on one leg and 20A on the other leg. This is not the same as a 50A RV plug which gives you 50A on each leg.
It also does not work if either plug is a GFCI and 20A GFCI plugs are common in a CG. It also connects the 20A and 30A neutral together which can result in one of the neutrals being overloaded. Some CG's don't allow the cheater cord and they are very justified in that requirement. The others most likely are clueless about what they are allowing.
Dennis Bham
Alabama
Posted: 03/06/12 06:50am Link  |  Print  |  Notify Moderator
I have a single 15K AC and a 33' trailer. When camping in the Cape Canaveral area in the summer, cooling has been barely adequate when exposed to the full sun all day. I slipped large reflective car-type windshield shades between the windows and the blinds on the sunny side of the trailer. Also put shades under the 2 skylights. When in moderate or better shade, we have no cooling problems at all tho.
With a 37' trailer, if you are going to be in full Florida summer sun, I recommend the second AC.
'08 Chevy 2500HD Duramax 4x4, Crew Cab, Std Bed e/w 18K Superglide
'08 Cougar 292RKS, e/w 16" Sendel wheels & BFG Commercial TA tires
PressurePro TPMS
BCSJBaylor
Bath, PA
Posted: 03/06/12 07:07am Link  |  Print  |  Notify Moderator
We will be in Fort Wilderness (Disney) for 7 days, then heading up to the KOA in Pigeon Forge, TN for 4 days. I know that FW is rather shaded so hopefully I won't have a problem there. Pigeon Forge KOA can be shaded or open depending on where they put us.
I'll have to check the AC and see what it is. I didn't know there was such thing as a 15k unit, so maybe it has that and not the 13.5K I'm used to. As I just bought the thing and had it delivered in December, I haven't even turned the AC on yet. We're doing a shakedown trip beginning of May to check everything out.
Me, '66
Dear, '66
Princess, '90
Prince, '92
Prince, '97
2007 Keystone Challenger M-34SAQ
2005 Ford F250 Super Duty Diesel
CA Traveler
The Western States
Posted: 03/06/12 07:23am Link  |  Print  |  Notify Moderator
Some CG's are set up this way and the second plug is available if the adjacent site is empty.
But with 2 30A overloading the neutral is also possible unless the 2 hots are on a split phase circuit.
Snowman9000
IL
duplicate, deleted.
