RV.Net Open Roads Forum: When using an mobile dump service to pump your...
 > When using an mobile dump service to pump your...
AZPops
Wherever the Job takes us...
Posted: 03/05/12 06:27pm Link  |  Print  |  Notify Moderator
...holding tanks. Do you need a special connection, or contraption/fitting to have this type of service done?
And is there any precautions I should be aware of while having the tanks pumped/drained?
Thanks,
Pops
larry cad
ohio
Posted: 03/05/12 06:31pm Link  |  Print  |  Notify Moderator
No
Our Travel Blog
AZPops
Posted: 03/05/12 06:32pm Link  |  Print  |  Notify Moderator
larry cad wrote:
No
Wow, that was easy! Thanks!
Lobstah
Northeast
Posted: 03/05/12 06:47pm Link  |  Print  |  Notify Moderator
Sometimes it's just that simple
Jim
2005 Pace Arrow 36D
Very Understanding Wife
2 Boxers
4 Cats
Kiwi_too
Western, WA
Posted: 03/05/12 06:51pm Link  |  Print  |  Notify Moderator
No, if all is working well. Make sure that your vents to the roof work right. If they are stopped up, I believe the pump could create a vacuum with potential to collapse or cause damage to black tank. If vent pipe is clogged, you can prop the toilet open, while pumping, until you get the vent fixed. Grey should be open by virtue of p traps and shower straight pipe.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
rv2go
Fulltime (Knoxville, TN).... or someplace else
Posted: 03/05/12 07:08pm Link  |  Print  |  Notify Moderator
Some pumpers will ask you to prop open the toilet valve. This is in case the vent pipe could be clogged. Some pumpers are quite powerful and could collapse the tank. As stated, so so much a problem on the gray tank.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
PapPappy
Wilmington, NC
Posted: 03/05/12 07:22pm Link  |  Print  |  Notify Moderator
Usually, the guy with the truck will know what you need to do, and will, as mentioned, tell you to do certain things....
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.
Purchased April 2008 FMCA# F407293
The Pets
Twomed
FL winters and then somewhere cool
Posted: 03/05/12 07:30pm Link  |  Print  |  Notify Moderator
It's basically like a big vacumn sweeper. So he turns it on, you pull the plug and he is just sucking it up...so no special fittings are used. Easy as pie.
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Weathertodd221
FL
Posted: 03/05/12 07:41pm Link  |  Print  |  Notify Moderator
what black tank will collapse under the suction of a poop truck?
Answer is NONE unless you have a black tank made out of a milk jug.
D.E.Bishop
Eagle Rock, CA
Posted: 03/05/12 07:29pm Link  |  Print  |  Notify Moderator
Larry, love your answer, says it all and love your tag line, a new PB every day how encouraging.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
